It is currently Sun Nov 29, 2026 7:02 pm
 Post subject: Aarrrgg!
PostPosted: Fri Dec 03, 2004 7:32 pm
Sorry /ers
I misunderstood when I posted the autozone p/n I thought you were refering to the Intake/exhaust Gasket itself. :cry:
When in doubt, empty the magazine.
'72 Dart Swinger /6 - My Yard Dart!
'01 Ranger P/U 4x4 X-cab
We buy and sell MOPARTS & Ford Parts!!!
http://www.usironauto.com
PostPosted: Fri Dec 03, 2004 8:24 pm
...unless the 70-72 specific is different
You got it, it's different. There is a great big hole in the top of the #4 exhaust runner in the manifold. There is a seperate steel "bathtub" and an associated gasket. V8's had a similar arrangement for several years starting in 1970 - but the gasket and chokewell is bigger and not interchangeable. For some reason, those gaskets are still easy to find AND they aren't as close to the exhaust port, so they don't get as hot.
D/W
If it ain't broke, fix it!
PostPosted: Fri Dec 03, 2004 8:29 pm
Thanks for trying, but as noted above, the V8 chokewell is different. :(
D/W
Footnote: I just discovered my gasket sheet (the good stuff, or at least the goodest you can get anymore) has a PART # and a name!
Fel-Pro 2499 "Fel-ramic"
PostPosted: Fri Dec 03, 2004 9:15 pm
Yes they did change the manifolds after a certain year to close off the choke stove pocket so you didn't need a gasket.
Call up Cox Bros or clifford, they sell a thick header gasket that they get custom cut for a slant 6 pattern, maybe they can sell you a small scrap piece for cheap.
I believe someone on here bought the dorman manifold, but it wasn't more then $150, try www.kragen.com or www.rockauto.com .
Users browsing this forum: Bing [Bot] and 7 guests
