| anyone running 2 oxygen sensors? https://slantsix.org/forum/viewtopic.php?t=12408 |
Page 2 of 2 |
| Author: | 440_Magnum [ Thu Apr 07, 2005 7:20 am ] |
Quote: a battery?
"Battery" was more of an analogy than anything else. Its definitely not a thermocouple though. True, it has to be hot to operate, but the voltage isn't temperature dependent in any way as it is in a thermocouple. The voltage originates because of a chemical process catalyzed by platinum in the sensor, so I would still say that "battery" is a pretty good analogy.Are o2 sensors not more of a generator or thermocouple? The point is that its a high-impedance voltage source, and the only way to mess up its readings is to hang a meter with too low an input impedance on the output. Whether you think of it as a battery, fuel cell, generator, or voodoo is irrelevant as long as you remember that it is high impedance. |
| Author: | Bob D [ Thu Apr 07, 2005 8:29 am ] |
Although an oxygen sensor is not a "storage" battery, I believe that they are considered a battery because it is a chemical reaction that creates the voltage. They actually have a solid electrolyte. A thermocouple, on the other hand, is based on the Seebeck effect which creates a voltage when two wires of the thermoelectric series of elements are connected together. Bob D |
| Author: | Dart270 [ Thu Apr 07, 2005 5:16 pm ] |
Yep, O2 sensor is like a battery in that it generates a voltage, but very small current (high impedance as 440 said). Practically speaking, you need to read it with a digital voltmeter (not an analog meter) since its impedance will be much higher than an analog meter. Lou |
| Page 2 of 2 | All times are UTC-08:00 |
