| Starter motor geekery https://slantsix.org/forum/viewtopic.php?t=12718 |
Page 2 of 2 |
| Author: | steponmebbbboom [ Tue Apr 26, 2005 8:48 pm ] |
| Post subject: | Re: thanks |
Quote: From my experience, a common problem was that backfires could crack in the nose of the starters
Ive noticed that too in a lot of forklifts, and the mfr of a few makes have come up with "ignition delay" modules (the simplest being a 1/4 sec. delay timer mounted in series with the coil positive feed from the keyswitch), which allows the starter to fully engage and rotate the engine a little before turning on the coil. This way, the engine wont kick back and give the nosecone that weird loading that breaks it. Electro.sonic should have a delay timer you could wire in to solve that problem. Ive used them a few times while I was at Liftow.
and the clutch would break, |
| Page 2 of 2 | All times are UTC-07:00 |
