| Electronic Ignition https://slantsix.org/forum/viewtopic.php?t=12785 |
Page 2 of 2 |
| Author: | 440_Magnum [ Fri Apr 29, 2005 9:53 am ] |
I prefer retrofitting with Mopar electronic ignition for several reasons, although all the other suggestions will work. 1) I understand Mopar EI, it looks "factory" even in an older car, and its simple. 2) If I'm driving in Bug Tussle, Texas or Eudapimp, Idaho and have an ignition failure, the local auto parts store WILL have a replacement part (this actually applies to HEI also). Just try to get a Pertronix or MSD part in Bug Tussle on a Sunday afternoon 3) Its so dang reliable it won't break anyway (same could be said for HEI). |
| Author: | slantvaliant [ Fri Apr 29, 2005 11:49 am ] |
Well, if a Pertronix module failed in Notrees, Texas, you could replace it with a very compact, inexpensive set of points from your road bag. |
| Author: | 440_Magnum [ Fri Apr 29, 2005 3:20 pm ] |
Quote: Well, if a Pertronix module failed in Notrees, Texas, you could replace it with a very compact, inexpensive set of points from your road bag.
And all for less than a dime, if it happened in Old Dime Box. |
| Page 2 of 2 | All times are UTC-07:00 |
