| How to make my fast looking Scamp actually fast https://slantsix.org/forum/viewtopic.php?t=12806 |
Page 2 of 2 |
| Author: | 69Fastback [ Sun May 01, 2005 10:25 am ] |
Quote: Turbos are perfectly streetable. The Auto manufacturers would not be putting them on new cars if they were headaches.
What turbo are you running?
Every engine that has been in the simca would be a perfect street motor. No wild cams(MP cam), no high comp(8.5-1), stock rods(used both 198 and 225), off the shelf pistons(hypereutectic 2.2 turbo pistons). Heck the first motor had stock cast pistons and ran 6.50' on 13-14# of boost. Had over 250 runs on it and never gave us any problems. The only thing we do that would not translate to the street is methanol BUT converting any of these motors to gas would not be difficult and probably a little cheaper because of small injectors. The biggest expense would be fabricating a plenum and exhaust manifold. Megasquirt like Lou madsen runs would be a good choice and work well. Even the Holley stuff would work well. The motor itself is a pussycat compared to the motors in some of the other fast cars...but put the boost to it and look out. I believe you could take any one of the two motors we have run and put a street car in the bottom of the 7's(1/8) without much effort. Heck we would even be willing to help someone with the tune-up if they show up at the races just to have another turbo car out there. Turbos add an incredible amount of torque(what you want in a street car anyway) as well as increase the hp nicely. The run at Bristol last year was 9.85 on 12# of boost and that is not a lot of boost. (I believe the STR-4 Neons have 15 from the factory) The RPMs never reached higher than 5800 in any gear. How much more of a street car could you ask for. |
| Author: | Tom Drake [ Mon May 02, 2005 3:53 am ] |
T60-1 |
| Author: | 440_Magnum [ Mon May 02, 2005 7:21 am ] |
Quote: Turbo is not drag power thats interesting . Last year At Bristol Tenn Tom Drake went the fastest time down a drag strip any Slant door slamer car has ever done.
I think the point was that a turbo is STREETABLE power, whereas "drag power" can also be a 4-bbl, tons of head-work, 11:1 compression, a monster cam, 4.10 rear gears, and 3500-RPM stall convertor, all of which would make the car almost impossible to live with on the street.
| Author: | Dart270 [ Tue May 03, 2005 6:25 pm ] |
Heh, that's funny. I just was doing turbo calcs and came up with the T60-1 as a good contender. Cameron Tilley is running a modified T4 on his Valiant. See y'all at Farmington - can't wait to get back! Lou |
| Author: | gmader [ Tue May 03, 2005 7:50 pm ] |
| Post subject: | take a look at a couple of other options |
I looked at a few turbos, and here is what I am planning on putting on my slant http://www.turbocalculator.com/map-t04b ... 0H3%20Trim It is cheaper, and I think from looking at the maps, a better fit. This one looks even closer as a fit http://www.turbocalculator.com/map-t04e ... 054%20Trim Greg |
| Page 2 of 2 | All times are UTC-08:00 |
