SS Brakes - I can stop now! (ALSO have poll)
https://slantsix.org/forum/viewtopic.php?t=12807
Page 2 of 2
Author:  Rust collector [ Wed May 04, 2005 3:34 pm ]
You need some grease on the pads!
I have never heard a cop complaining about too good brakes...
Author:  kesteb [ Fri May 06, 2005 4:41 pm ]
My '65 Dart has the disk brake setup from a '75 Dart SE. The rear brakes are also from the same car. The master cylinder is a 2 bolt aluminum set up from a '80 Volare with manual disk brakes. The proportioning valve is from a disk brake '73 Dart. The car stops straight and true, a vast improvement over the OEM 9' brakes.
Author:  andyf [ Fri Jun 03, 2005 10:19 pm ]
Yep, I swapped on some disc brakes onto my '65 also. I went with the bigger version.
Page 2 of 2 All times are UTC-07:00
