| fuel gauge conk out looking for the di or the doctor https://slantsix.org/forum/viewtopic.php?t=12985 |
Page 2 of 2 |
| Author: | emsvitil [ Mon May 23, 2005 12:21 am ] |
| Post subject: | Re: Totally foobared! |
Quote: Well I found the problem. At first I was ecstatic. I dropped the tank part way, and was able to extract the sending unit.......................
So that's what I have to look forward too when I finally get around to the fuel sending unit................Upon complete removal of the sending unit, I noticed it looked pretty rusty. Then I tried to move the float arm...it had some resistance. THEN the really bad stuff happened--I made the mistake of looking at the internals. Apparently the car must have sat for a VERY long time without much gas in it, because the entire sending unit is rusted up good. Peering into the internals, I noticed something that gave me pause--the electrical pickup the float arm is supposed to move against seemed a bit out of place. Closer inspection revealed it wasn't attached at all, and a slight shaking produced a most disheartening result--it simply fell out in two pieces.............. |
| Author: | NewLancerMan [ Mon May 23, 2005 6:03 am ] |
yeah it was wonderful MJ |
| Author: | K.Beard of TMC [ Mon May 23, 2005 9:51 am ] |
| Post subject: | sending unit |
Several times I've had sending units corrode and I couldn't find replacements. I found that J.C.Whitney sells a universal one for Mopars; its instructions tell you to cut a big hole in the tank to install it seperate from the old pickup. To avoid that I screwed the new resistor, arm, and float onto pickup tube in place of the old ones. Before I did that, I measured the motion of the original arm and bent the new arm to approximate it the best I could. I've done it several times and it always has worked well. It is important that you make a good ground to the new sending unit. |
| Author: | NewLancerMan [ Mon May 23, 2005 12:23 pm ] |
I was looking at the tubes and wondering how they go through the top. They appeared to be 1 piece or atleast soldered. How did you remove them? Thanks! MJ |
| Page 2 of 2 | All times are UTC-08:00 |
