Distributor vacuum can specs (list)
https://slantsix.org/forum/viewtopic.php?t=13198
Page 2 of 2
Author:  fonzy [ Fri Mar 27, 2015 1:00 pm ]
Wow. this is greek to me! I really want to try to understand this but am a bit of a loss where to begin. I do have a few questions already though, my 66 225 sl6 valiant has the CAP system on it, and it's ignition was upgraded to the mopar electronic ignition with a 76 distributor. How does all this affect the vacuum curve? Is my 66 missing out on some fuel economy due to a differing vacuum curve? I did replace my vacuum advance with the 76 advance(it is a 76 distributor, #3874598), it has an 8.5 on the arm of the advance.
Author:  Aggressive Ted [ Sat Mar 28, 2015 9:15 am ]
Post subject:  Distributor recurve
It depends......what mileage are you getting now?
If your already at 21.5 for local and 25+ on trips don't worry about it. If not, then there may be some improvements you can make through recurving the distributor. See "Recurve Threads" in the Engine FAQ. Also see http://www.slantsix.org/forum/viewtopic.php?t=38471 and http://www.slantsix.org/forum/viewtopic.php?t=38465
Author:  fonzy [ Sun Mar 29, 2015 5:22 pm ]
I'm lower than that..around 14 mph in the city.
Page 2 of 2 All times are UTC-07:00
