| What should I do? https://slantsix.org/forum/viewtopic.php?t=13456 |
Page 2 of 2 |
| Author: | vinnie1069 [ Sat Jul 23, 2005 2:45 pm ] |
oh damn now i really feel like an idiot! |
| Author: | vinnie1069 [ Mon Jul 25, 2005 3:55 pm ] |
well nevermind on enlarging the ports. He can help me with taking it apart and cleaning and maybe just smoothing the ports and clearing them of any obstructions. Do you think that that would be good? This seems like a one or two day job so it wont be a big deal. Thanks |
| Author: | buddy [ Tue Jul 26, 2005 4:46 pm ] |
Just a couple of thoughts about things I learned on my first car: 1. Just drive the car as-is for at least 2 months (3 months is better) before you spend the first dollar on modifications or accesoories. Why? To see if any serious problems pop up and require your money and time to remedy. Plus, it gives you time to gain knowlege and create a plan so you can get it right the first time. 2. Spend your time and money on 1.) learning [shop manuals, etc.] 2.) safety [brakes, steering, suspension, etc.] 3. reliability [cooling system, ignition/electrical system, fuel system] before anything else. In other words, learn and perform the basics first, before you modify anything. How are your modifications going to maximize performance if your basic mechanicals are losing performance? Or worse, what will you do if, say, the brakes fail because you didn't check/didn't know how to check that system? Its hard to modify a car when its wrapped around a tree; it really messes up the handling. 3. If you're going to do major repairs, restoration, or modification, find something else to drive while you work on this one. You can't do a major project on a car while you're using it; believe me, I've tried...it didn't work. Please don't be discouraged if it sounds like you shouldn't modifiy the car right away and have to suffer with poor performance. If you do the things I suggested, you might be surprised at the performance you can get out of a stone-stock car. A sharply-tuned stock slant runs pretty decent, especially if you advance the distributor a few degrees. I hope this gives you some insight. If someone had told me this when I got my first car, it would have saved me tons of headaches and heartaches, as well as making my efforts much more successful and a lot more fun. Congratulations and good luck! |
| Author: | vinnie1069 [ Thu Jul 28, 2005 2:13 pm ] |
Thanks for the advice buddy, but the thing is, i dont have my liscense yet so i am going to do all the stuff i can to the car before i can drive it everyday so that i can drive it reliably when i do get my liscense. |
| Author: | Ron Parker [ Thu Jul 28, 2005 4:10 pm ] |
Dan is your man cannot go wrong with his advise. A good check of everything like compression and tune up specs are inportant. Remember a stock slant six in a body is not going to be fast. I bracket raced two i drove on the street. A 74 Dart Sport 19.91 was the best it ran in the 1/4 and the car i race now it was like 20.05 in the 1/4. Thanks Ron Parker Hell Hath No Wrath Than A Possum Scorned |
| Author: | Jeb [ Thu Jul 28, 2005 5:56 pm ] |
Hey Ron what gears are you running. My car has 2.76 gears and I had a buddy time me whle I ran down a backroad (slightly downhill) and the best I got was 19 seconds. Do you think my times would be about the same as yours on level ground in a real quarter mile? My slant is completely stock and is a 74 Duster. |
| Author: | Ron Parker [ Thu Jul 28, 2005 7:44 pm ] |
Nope not unless you can go 12.60 in the 1/4 i doint see that . Thanks Ron Parker Hell Hath No Wrath Than A Possum Scorned |
| Author: | slantvaliant [ Fri Jul 29, 2005 6:49 am ] |
One thing you can do when you don't have money to spend on the car: Clean. Anywhere. Everywhere. Upholstery, carpet, dash, glass, grille, lights, trunk, engine bay, underside ... Everywhere. Your own elbow grease is pretty cheap. You also get to know your car much better that way. You'll thank yourself whenever you have to work on something and find that it's not covered with goo. |
| Author: | vinnie1069 [ Fri Jul 29, 2005 1:32 pm ] |
thanks for that advice. That is actually what i was planning to do. I wanted to clean every thing i could for free to the car, then start to spend money on it. I am actually helping my friend restore a '71 charger w/ a 318. It is a great experience and i am learning a bunch about old cars. That is actually the reason i am getting an older car, instead of some new import or some thing. Thanks, David |
| Page 2 of 2 | All times are UTC-08:00 |
