It is currently Sun Nov 29, 2026 11:39 pm
PostPosted: Wed Dec 28, 2005 8:20 pm
That looks kinda familiar.............
Did you mount the top bolt all the way thru the K-member?
BTW, Nice looking K-member 8)
PostPosted: Wed Dec 28, 2005 8:30 pm
Yes, there was a hole that I could use for the top mount. The bottom hole on the K-member had to be drilled for the angle bracket.
Thanks for the compliment on the k-member. I got it from FirmFeel, due to my old one being seriously messed up.
PostPosted: Thu Dec 29, 2005 6:22 am
Nice work, Greg. Unless I miss my guess, that sway bar is made by Addco, or at least looks identical (incl mounts). I would recommend tack welding the angle mounts on the LCAs in addition to the shock bolt. Otherwise, they will rotate and move around eventually.
