8 bolt rearend!&#@% confused!!
https://slantsix.org/forum/viewtopic.php?t=13939
Page 2 of 2
Author:  Charrlie_S [ Sun Aug 07, 2005 5:41 am ]
There is your problem. Someone changed out the rear, at one time to the small bolt pattern drum brake unit, or did a disc brake conversion. What you will need to do, to get the same bolt pattern, front and back, is to change the rear, to a 7 1/4 from a disc brake "A" body, or convert to a 8 1/4 rear.
Author:  exoJjL [ Mon Aug 08, 2005 4:51 pm ]
what size is the small bolt pattern? a 8 1/4 will bolt right in pretty much??
Author:  Charrlie_S [ Tue Aug 09, 2005 5:37 am ]
The large bolt pattern is a 4 1/2 inch bolt pattern. The small is 4 inch bolt pattern. A 8 1/4 rear from an "A" body will bolt in, be will need a shorter driveshaft. Take a look here.
http://www.slantsix.org/forum/viewtopic ... highlight=
Author:  Matt Cramer [ Tue Aug 09, 2005 7:02 am ]
metric bolt pattern???
5 x 100 mm. Almost, but not quite, the same as 5 x 4". The offset is usually wrong, too.
Author:  skraecken [ Tue Aug 09, 2005 7:27 am ]
5x100 = Toyota Camry -91
Author:  exoJjL [ Tue Aug 09, 2005 11:38 pm ]
wow
Author:  Charrlie_S [ Wed Aug 10, 2005 6:57 am ]
Just to restate: I would not use the 100 mm wheels, except as a spare.
Author:  exoJjL [ Wed Aug 10, 2005 7:11 pm ]
Post subject:  confusing this is
of coarse.
Page 2 of 2 All times are UTC-07:00
