| Where to look for a low gear 904?? https://slantsix.org/forum/viewtopic.php?t=14477 |
Page 2 of 2 |
| Author: | SlantSixDan [ Sun Sep 25, 2005 8:02 am ] |
| Post subject: | Re: Enlighten us, please. |
Quote: ...are we sprechen Deutsche now?
Given that I'm typing this from Frankfurt...ja!
| Author: | featherduster76 [ Sun Sep 25, 2005 10:40 am ] |
| Post subject: | Converter |
Ok, I'd like to know where is a good source to find a lockup converter, I need a performance one. Thanks guys... |
| Author: | 73ScampSSS [ Sun Sep 25, 2005 9:52 pm ] |
I heard the governor weights in the tail section must be changed with the rest of the guts, which makes sense, at a lower ratio the same engine rpm would achieve a lower output speed, so it would have to shift sooner |
| Author: | Dennis Weaver [ Mon Sep 26, 2005 6:28 am ] |
..yeah, but you don't want that with any kinda performance use. Stick with the original weights. D/W |
| Author: | featherduster76 [ Mon Sep 26, 2005 2:35 pm ] |
| Post subject: | original 904?? |
So it seems to me it just maybe best to stick with my 'ol 73 a904?? |
| Author: | Dennis Weaver [ Mon Sep 26, 2005 5:52 pm ] |
| Post subject: | Re: original 904?? |
Quote: So it seems to me it just maybe best to stick with my 'ol 73 a904??
Why? The lower first gear can really help get you out of the hole.D/W |
| Author: | Rust collector [ Mon Sep 26, 2005 6:15 pm ] |
Does it really make much difference in a light a body? Could a converter be a good alternative? I guess the low gears would help a heavy car more... |
| Author: | Lars [ Mon Sep 26, 2005 11:43 pm ] |
Also, though not the cheapest. Mancini racing carries low gear sets for the 904 for about $180. Could save you some scrounging time and such. |
| Author: | featherduster76 [ Tue Sep 27, 2005 7:06 pm ] |
Oh ok...Good point taken D/W. I was looking at some lock up converters and noticed they were pretty expensive, so I guess Im juggling my options here...thanks |
| Author: | Dennis Weaver [ Tue Sep 27, 2005 8:10 pm ] |
Quote: Oh ok...Good point taken D/W. I was looking at some lock up converters and noticed they were pretty expensive, so I guess Im juggling my options here...thanks
You definitely do NOT want the lock-up converter. Just put the low gears in whatcha got.D/W |
| Author: | Slant6Ram [ Wed Sep 28, 2005 6:53 am ] |
| Post subject: | On the topic of converters |
The use of the low gearset was an economy minded solution to a problem which is already solved by other products. (such as a performance converter) If you are mostly racing, just get a high stall racing converter. This will get you out of the lights in a hurry with the standard gears. I don't know where the trade off between performance and street driveability and economy really curves, but I know that the stock converters are leaning heavily to economy. If you've got the $180 for a mancini gearset, I suggest you instead keep saving and get some better suggestions about what kind of performance converter will stall at a good place for your motor, car, and driving requirements. I suspect you'll need between $300-$500 for the converter that will really make it zoom! Good Luck! |
| Page 2 of 2 | All times are UTC-07:00 |
