gas mileage
https://slantsix.org/forum/viewtopic.php?t=14747
Page 2 of 2
Author:  argentina-slantsixer [ Sun Oct 23, 2005 2:10 pm ]
Ok, it was a manual 3 speed ok, and if the ground was about flat, I didn´t have to hold the brakes on before I changed to synthetic oil...IN THE TRANNY AND REAREND, the engine got old dinos in it...
Soooo, I guess it makes for less friction, and a bit of mileage :?
hehe, we couldn't resist either way...
sure makes less friction. I'm about to change my rear axle lube and I'll be using synth as well.
Author:  Rust collector [ Sun Oct 23, 2005 3:36 pm ]
:P :lol:
Author:  1966 dart wagon [ Mon Oct 24, 2005 11:12 am ]
well syn anything will only help(unless you have full syn i heard that shrinks gaskets) :shock: :?
better gas milage lets see
2bbl carb
2 1/4 exhaust
what is your rear end gearing do u drive on the highway alot? if so 2.76 will help a ton :wink:
check your alignment
maybe adjust your current carb is it running rich? :shock:
Page 2 of 2 All times are UTC-07:00
