It is currently Fri Nov 20, 2026 5:19 am
Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Weld Ells?
PostPosted: Sun Oct 30, 2005 2:59 pm
Weld Ells are used extensively in the High pressure Pipeline industry. We use them all the time in the natural gas Transmission industry. The 90's come in short radius and long radius for making shorter bends or longer bends. This gives you some flexibility in routing things. All the fittings come pre-beveled so you can clean up the ends and lay a nice weld down in the bevel and you are set. Actually our welders make 3 passes on them but then again, when you are working with 2400 + pounds you don't want any problems. Pre heating a little is always wise on heavy materials because you can easily see the water coming out of the metal when you do. From what I have seen, all the fittings that we get are forged steel and high strength grade fittings. I don't think there are any "plain" steel fittings out there. They are all pretty tough materials. With that said, for what we are talking about, the lowest strength & thinnest wall thickness is probably much more than we would ever need. So it should work well.
If you know someone who works at a pipeline co. ask them where they get stuff locally. Almost all towns of any size have an industrial supply store that could help you out.
Rick
 Post subject: Turbo in the back??
PostPosted: Sun Oct 30, 2005 3:05 pm
Have any of you seen the kits for trucks that put the turbo in the back? I wonder how well they work? For our slant cars you could run a regular set of headers (nothing to fabricate) and mount a turbo in the spot where the gas tank currently sits. Install a fuel cell in the trunk and away you go. It would eliminate some clutter under the hood as well. Just thinking out loud. What do you think?
Rick
 Post subject: Re: Turbo in the back??
PostPosted: Sun Oct 30, 2005 3:15 pm
Rick
2 words for ya...............
TURBO LAG
PostPosted: Sun Oct 30, 2005 8:55 pm
Well, I guess if you were really wanting to make a 'sleeper' that would work. I'm going to look around town for some of these pipe fittings.
What kind of weld is best for that type of material/situation? It seems like a stick welder would work pretty well, not that I have one or anything.
I am trying to find a mig for a price that I like but that is more for some body work that I need to take care of.
the most expensive free car I ever got - 74 special edition
 Post subject: rear turbo
PostPosted: Sun Oct 30, 2005 11:28 pm
Rick,
I was thinking the same thing. I saw an article on that, but it was for the LS-1 camaro/trans am conversion.
The turbo actually replaces the muffler, so I don't know if you would have to move the gas tank. The fact that it is so far back REDUCES lag, and there was no need for an intercooler 'cause the pipe back to the front was so long the air gets cooled before it reaches the front of the car.
I think the kit was about 4 grand, though I suppose you could fab your own.
"Nothing in all creation is hidden from God's sight. Everything is uncovered and laid bare before the eyes of Him to whom we must give account."
PostPosted: Mon Oct 31, 2005 4:20 am
Any plumbing supply store will have them available. another source is, WW. Grainger, or McMaster-Carr.
Mig is the best/easiest, for welding
PostPosted: Mon Oct 31, 2005 7:01 am
There is just NO way that would be true, the same turbo on the engine would spool faster, but I don´t think lag is much of a problem with any location, as long as the unit is selected for what it is supposed to do.
Someone who knows enough, could probably have the turbo on a trailer, and still get little lag, but not the best performance.
The other issue with the remote mount turbos is that you need a pump to drain oil UP to the oil sump...
There are "many" people who are very happy with them, for mild setups.
PostPosted: Mon Oct 31, 2005 1:53 pm
Boost threshold is far more important to worry about than the so called "lag".
Nitrous cars are like old men on Viagra. Once the bottle is empty they are useless.
FJD
PostPosted: Tue Nov 01, 2005 5:41 am
My understanging is that those rear-mounted turbos were invented for late model F-bodies as a way to work around their limited underhood space. The engine is practically halfway under the windshield. Not really an issue on a slant six.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Thu Nov 03, 2005 11:42 am
Lag is very real even in factory installations. My daily beater last winter was a Turbo II daytona mash the gas count to two and away we go. Mounting the turbo farther back will increase response time over one mounted to the manifold. Plus the exhaust will cool considerable before it gets to the turbo if it is in the back and heat is good for a turbo. Plus what kind of intake plumbing nightmare would you be getting yourself into. Oil lines, coolant lines if you want to play with the turbos hang out on www.turbododge.com for awhile there are some good intelligent guys on there.
PostPosted: Thu Nov 03, 2005 11:54 am
What you are describing is not lag but you are below the boost threshold on the turbo. Lag is when the turbo is turning enough rpms to make boost and you nail it and lag is the time it takes for the turbo to overcome the internal inertia.(once it is already making boost)
Boost threshold - rpms below the point the turbo makes boost. Too big of a turbo could have a 5000 rpm boost threshold on a certain motor. A smaller turbo on the same motor could have 1800 rpm threshold.
Right now the threshold on the Simca is around 3200rpms. We could change the internals of the turbo and change the threshold. If we launch the car now at 2000 with no boost and it takes 2 secs for it to reach 3200 and start building boost that is not lag.
Tom
FJD
PostPosted: Fri Nov 04, 2005 7:00 am
Is boost threshold load sensitive. On mine no boost in first without 3/4 or more throttle and then not until around 4K. In second it will max boost around 3200 and in 3,4,5 it will max around 2500. I don't use the factory boost controller just a grainger valve set to 14 psi. Either way I like lag time compared to instant boost. I've drove the evo lancers and srt4 neons and didn't care for them. They don't whistle they spool too quickly. I like my turbo to do nothing then start to whistle and then the huge rush of power.
PostPosted: Fri Nov 04, 2005 7:08 am
Lag is not to be confused with the boost threshold, however many publications still make this basic mistake. The boost threshold of a turbo system describes the minimum turbo rpm at which the turbo is physically able to supply the requested boost level. Newer turbocharger and engine developments have caused boost thresholds to steadily decline to where day-to-day use feels perfectly natural. Putting your foot down at 1200 engine rpm and having no boost until 2000 engine rpm is an example of boost threshold and not lag.
FJD
PostPosted: Sat Nov 05, 2005 2:40 pm
So what turbos work well with the slant? I read the t-3 is good, but I'm seeing a lot of t-3/t-4 hybrids too. I ran a 'turbo calulator' at work and it said I needed a .64 exhaust spool. I don't know how valid that is. I'm personally running .040 over with stock compression for my application. Speaking of which I need to find out more about the 2.2 pistons. Later!
PostPosted: Sat Nov 05, 2005 3:32 pm
Sure, the t3 is good, but there are a few hundred DIFFERENT t3´s out there.
It is a "family" of turbos...
like holset hx series, is a family, used on engines from 2.5(?) to at least 20 liters...on a single instalation (not twin turbos)...
The t4/t3´s also come in different sizes, and wheel trims, so you really have to find info on ONE turbo, then see if it match your engine.
If it doesn´t, look at another map, and see if it fits, or not..............
It requires some math :cry:
The exhaust housing a/r ratio has more to do with when the turbo begin working eficiently (and to a degree how much exhaust flow it can pass, before being too restrictive(combined with the turbine wheel used) and start choking power)
Yes!, kinda... I think it goes something like: When you are in 2nd, or 3rd, the engine load is higher, and it makes more exhaust for the same rpm number, so it turns the turbine faster, with lower engine rpm´s than in 1st, where the engine doesn´t see enough load...
Go listen to a big diesel truck somewhere.
If the driver is young, he will nail it in low gear, and you will probably hear the turbo spooling up at a higher rpm than the old guy, who let torque work, and you will hear the engine working, then the turbo will spool like crazy at low engine rpm.
