It is currently Sat Nov 21, 2026 6:34 pm
Post new topic  Reply to topic  [ 69 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Tue Nov 08, 2005 9:43 pm
Hmmm, I just bought a new Carter fuel pump that's rebuildable, and it's supposed to fit any Mopar Slant 6 or smallblock according to mfgr.
JimmieDart
PostPosted: Wed Nov 09, 2005 4:35 am
where and what was the part number?
PostPosted: Wed Nov 09, 2005 10:32 am
Doubt it. There's no such thing as a fuel pump that fits slant-6 and V8. The arm is different, clocking is different, pressure and volume specs are different...
...can you show us where the manufacturer made this claim?
PostPosted: Wed Nov 09, 2005 7:07 pm
I'm hijacking my own thread.
Could a cylinder head crack in the valve area cause these symptoms, or is there something else Im missing?
PostPosted: Wed Nov 09, 2005 7:14 pm
Symptoms...?
PostPosted: Wed Nov 09, 2005 8:10 pm
Sorry, I was in a strange mood. The new Carter pump I just bought fits /6, all smallblocks and most big blocks, mainly because it's electric: but it is indeed rebuildable! Warped sense of humor I guess....
JimmieDart
PostPosted: Wed Nov 09, 2005 8:18 pm
PostPosted: Thu Nov 10, 2005 12:44 pm
Is the number embossed anywhere? As it sits it tested at 4 lbs but is displaying symptoms of a bad pump. Runs nice for as long as you would expect it to before the fuel bowl empties, then it completely loses horsepower, backfires through the intake, and you have to pump the gas to keep it running. Other than the occasional backfire the engine runs smoothly even though it has no power. Come to a stop, take it out of gear and it runs like a watch. Take off again, same thing. Compression is 115 to 135, 1,2, and 6 are the highest. Needle valve looks fine. Plugs show lean. I havent checked valve clearance yet, Ill be doing that tonight.
These symptoms. The filter is new and a backflush didnt show any sediment, the pump puts out 4 lbs, still havent checked the valves, im going out to do that right now.
PostPosted: Thu Nov 10, 2005 1:16 pm
Well, OK, 4PSI is right in the middle of the spec, but have you done a volume test on it? (Or just swapped on a different pump to see if the behaviour changes)
Note there's another possibility here, if this is a high-miles unit: Sometimes the fuel pump eccentric on the camshaft gets a groove worn in it, such that it no longer operates the pump arm with a full stroke. In that case, the solution is either a new camshaft or an electric pump.
How sure are you that you're not just experiencing a carb problem?
PostPosted: Thu Nov 10, 2005 2:51 pm
The carb will be next. I volume tested the pump and it flowed quite nicely, but I did another road test and got around the block before it started stumbling, I limped home then ran it under load in drive until it coughed and died, then shut it off. I then took a nylon wire tie and dipped it 2&1/2" into the bowl through the vent hole, and only had 1/2" of gas on it, I disconnected the supply line and there was no spurt of fuel, only a dribble. Could be the float setting (which was fine before :?) but I am going to tee into the fuel supply line to the carb with my fuel pump tester and see if my pressure fluctuates. It may be time to drop the tank, or change the pump. Very odd, the filter and pump strainer are both clean.
PostPosted: Thu Nov 10, 2005 4:24 pm
Just did a running pressure test, pressure did not drop. The car loses power and backfires out the intake, recovers, backfires, recovers, etc. Must be the carb, but those damn sealed Holley metering blocks, I dont know that Ill be able to do anything about it. Yay Holley.
I have a Kem kit, I will check the instructions and see if I can raise the float level a bit. Thanks for all the help so far. Any ideas, chime in...
PostPosted: Thu Nov 10, 2005 5:15 pm
alright NOW Im confused... I never raised the float level but I did change the fuel filter, and ran it under load with the air filter off, it backfired and stalled again, I looked into the carburetor throat and it was soaked with fuel. Plugs are also soaked but are reading LEAN...
Now how in the hell can my main circuit suddenly become intolerably rich with the air filter removed and my choke wide open? This isnt making any sense.
PostPosted: Thu Nov 10, 2005 5:27 pm
Here's something interesting...
I decided to do a vacuum test under the same conditions. It started out idling smooth, but vacuum is a little low at 16" Hg, after running it at WOT in drive, it starts to lose RPM and backfires, take it out of gear and idle it, vacuum now reads 12" Hg and steadily rises to 16 after five seconds. So I am going to idle it until it gets up to operating temp and do a running valve adjustment, Ill let you know what I find... any thoughts?
PostPosted: Thu Nov 10, 2005 6:02 pm
Excessive exhaust back pressure...........
You don't happen to have a catalytic converter?????
PostPosted: Thu Nov 10, 2005 6:43 pm
nope, no cat... the problem consistently recurs upon sustained load.
An update, the exhaust valves were all tight, once I set them to .020 the vacuum gauge held at 18"Hg, much better, no more stumbling and smooth. Took it out on the road, much more power and throttle response, but after five minutes or so of hard throttle in traffic, the problem recurred. Acts as though it is running out of fuel... surging, losing power, no backfiring though... all I can do now is check and adjust the timing, and maybe raise the float setting a little, but I still have no clue. If I roasted my valves you would think it would show up on a compression test, but no, numbers seem ok...
it's a 64 engine with Chrysler distributor and solid lifters, Holley C-7064 carb with #65 jet, :!: 5000 miles on Autoline rebuild, slightly sloppy throttle shaft bushings, and plugs are clean, not flaky, reading slightly lean.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 5 guests
