| engine numbers https://slantsix.org/forum/viewtopic.php?t=15112 |
Page 2 of 2 |
| Author: | Charrlie_S [ Wed Nov 23, 2005 2:43 pm ] |
It sounds like this is a "reman" engine. Major engine reman shops use the screwed on or riveted tags. If the engine was done by one of these places, most likely they took a cut of the top of the block, and this could remove the factory numbers. |
| Author: | valiant effort [ Wed Nov 23, 2005 4:11 pm ] |
| Post subject: | numbers |
thanks Charlie..i suspected something like that..too bad..it does have solid lifters so i guess its pre 1980 and it does look like its a rebuild..actually looks pretty good inside except it looks like no one ever changed the oil.. |
| Author: | Charrlie_S [ Thu Nov 24, 2005 6:42 am ] |
The only things you need to be concerned about, as for the year, for parts, is: solid/hydraulic valve train, and cast/forged crank. Everything else will not make any difference in the year. You need to be more concerned with over/under sizes, that were used during the rebuilding process. |
| Author: | valiant effort [ Thu Nov 24, 2005 9:19 am ] |
| Post subject: | engine numbers |
how can i tell if its cast or forged crank? |
| Author: | dusty7t4 [ Fri Nov 25, 2005 6:40 am ] |
1975 and earlier used a forged crank, 76 and up is cast -dave |
| Author: | SlantSixDan [ Fri Nov 25, 2005 7:07 am ] |
Quote: 1975 and earlier used a forged crank, 76 and up is cast
No, actually, it's more complicated than that. The changeover from forged to cast was in the middle of 1976 production. All 1975 slant-6s have forged cranks, some 1976s have forged, some 1976s have cast, and all 1977-up have cast.This is for US/Canada/Mexico production; other plants worldwide may well have stayed with forged right through to the end. (Argentina-Slantsixer?) |
| Author: | relic-lover [ Fri Nov 25, 2005 8:02 am ] |
| Post subject: | Get a cup of coffee Dan |
Quote: and all 1977-up have forged.
That is just plain wrong - 77 and up would be cast cranks. |
| Author: | SlantSixDan [ Fri Nov 25, 2005 8:19 am ] |
| Post subject: | Re: Get a cup of coffee Dan |
| Author: | Charrlie_S [ Fri Nov 25, 2005 8:19 am ] |
The problem Valiant Effort is having, is, he doesn't know the year of the engine. I have been looking for my bearing book, so I could post the bearing sizes for the cast/forged crank, but it is misplaced. The forged crank has a 1, 2, 4, main bearing width, slightly larger then 1 inch. The cast crank has a 1, 2, 4, bearing width less then 1 inch. |
| Author: | dusty7t4 [ Tue Nov 29, 2005 12:03 pm ] |
Quote: Quote: 1975 and earlier used a forged crank, 76 and up is cast
No, actually, it's more complicated than that. The changeover from forged to cast was in the middle of 1976 production. All 1975 slant-6s have forged cranks, some 1976s have forged, some 1976s have cast, and all 1977-up have cast.This is for US/Canada/Mexico production; other plants worldwide may well have stayed with forged right through to the end. (Argentina-Slantsixer?) truth be told, I have have never had a crank or bearings fail anyway -dave |
| Author: | valiant effort [ Thu Dec 01, 2005 7:28 pm ] |
thanks again charlie..I will measure them and let you know.. |
| Author: | YeahBut [ Fri Dec 02, 2005 1:27 pm ] |
I also have a remafactured engine with a riveted tag on the block right side front just above the oilpan. It is painted black. My truck is a 67, but now the engine--block and/or head could be almost anything. I do have spark plug tubes--they are moist. Guessing from the posts, I am looking for an earlier block with a forges crank, and a later head with hydralic lifters? |
| Page 2 of 2 | All times are UTC-07:00 |
