| Addco sway-bar installation on 64 Valiant https://slantsix.org/forum/viewtopic.php?t=15325 |
Page 2 of 2 |
| Author: | emsvitil [ Mon May 29, 2006 3:16 pm ] |
Quote: What if I had a piece shaped like this?
Compress clay/playdough balls under points A and B as the plate is held parallel to the sway bar. The clay would give you the thickness and angles for the two wedge-shaped spacers. Bolts at A and B would go through the K I would probably file/grind the spacers from soft aluminum. The L-bracket could still reinforce hole C. Would the L-bracket be overkill if this mounts to the K-frame at two points? Would the triangular piece be too ugly? ![]() Doesn't even need to be that complicated..... Keep the Lower mounting point (with the L Bracket), and extend the upper bolt thru the K-member. The spacers are just because of the slightly different angles of the brackets and K-member. Like this (look at last picture at top of thread too)
| Author: | sixsignet [ Mon May 29, 2006 6:55 pm ] |
That is simpler. What happened to Lou's pics? How did he do it on his 64? |
| Author: | Dart270 [ Mon May 29, 2006 7:57 pm ] |
My webspace died for some reason. Need to get it running. On my 64 I just welded the addco mounts solid and welded them to the K near the front where the strut rod washers sit. Lou |
| Author: | NewLancerMan [ Mon May 29, 2006 8:44 pm ] |
Quote: That is simpler. What happened to Lou's pics?
sorry moved stuff around on my website and didn't realize the links were broken. They're fixed now.
| Page 2 of 2 | All times are UTC-07:00 |
