It is currently Sun Feb 23, 2025 6:12 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
 Post subject: Re: Startup woes
PostPosted: Tue Dec 20, 2005 8:57 pm
It has spark while cranking, but the engine just coughs as the ignition switch is released.
The "cough" part I believe is a symptom of a magnetic pickup coil having been wired with reversed polarity. Something about the leading edge vs. falling edge of the signal triggering the electronics... where the pickup creates the wrong trigger but the removal of the start circuit voltage therefore creates the proper trigger. Have never taken time to think it through or verify it on a scope. I've heard of this complaint applying to standard Chrysler Electronic systems, but don't know if it applies to the LeanBurn system.
Not sure how this theory reconciles with "spark while cranking", unless perhaps a backwards pickup coil produces a very weak spark that you can detect in mid-air but is insufficient when under the pressure of a cylinder?
- Erik
Users browsing this forum: Bing [Bot], Google [Bot] and 54 guests
