It is currently Mon Nov 16, 2026 7:56 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Sun Mar 19, 2006 10:38 am
.....so I swapped the torque converter.....
Please tell me you drained and rinsed the converter out with some fresh fluid - chances are the metal powder you found in the original tranny has accumulated in the converter as well.
PostPosted: Sun Mar 19, 2006 1:42 pm
The converter had no drain plug, so I repeatedly dumped the fluid out of the back end until it was empty. It was the best I could do.
The trans works pretty good now. Sort of a harsh shift from 1-2, and when you put it in gear from idle you can't even tell the transmission is engaged until you take your foot off the brake. I still need to fine tune the kickdown linkage.
