| God-awful screaching from the transmission https://slantsix.org/forum/viewtopic.php?t=15974 |
Page 2 of 2 |
| Author: | Pierre [ Sun Mar 19, 2006 10:38 am ] |
Quote: .....so I swapped the torque converter.....
Please tell me you drained and rinsed the converter out with some fresh fluid - chances are the metal powder you found in the original tranny has accumulated in the converter as well.
| Author: | Reed [ Sun Mar 19, 2006 1:42 pm ] |
The converter had no drain plug, so I repeatedly dumped the fluid out of the back end until it was empty. It was the best I could do. The trans works pretty good now. Sort of a harsh shift from 1-2, and when you put it in gear from idle you can't even tell the transmission is engaged until you take your foot off the brake. I still need to fine tune the kickdown linkage. |
| Page 2 of 2 | All times are UTC-07:00 |
