| rearend swap https://slantsix.org/forum/viewtopic.php?t=16930 |
Page 2 of 2 |
| Author: | Ron Parker [ Mon Apr 10, 2006 6:37 pm ] |
About a pound a 741 case has a 1.50 pinion diameter. the 742 case has a 1.750 straight diameter and the 489 case has a 1.875 tapered pinion. All three will interchange but some combo gear sets wont. Aint that right Charlie. Thanks Ron Parker |
| Author: | carrigan #3 [ Mon Apr 10, 2006 8:16 pm ] |
thanks ron, i'm pretty sure the 741 would do just fine for me |
| Author: | rock [ Tue Apr 11, 2006 7:57 am ] |
| Post subject: | carrigan, a 741 is a fine pig |
Carrigan, Even though I swapped to a 489 case to get Sure Grip, the 741 pig is a fine piece of work. Mine was in a truck that worked hard and was torquing the 741 against some serious loads at times. Only reason (well ego played a part too) I swapped was I built a seriously improved motor and am toying with the idea of using a blower on it. In a car, even with a improved engine, a 741 should do well. I like the 741 so much I kept my pig for good luck. Be SURE you put in the mopar sure grip lube once when you swap. rock 64d100 |
| Author: | carrigan #3 [ Thu Apr 13, 2006 5:39 pm ] |
thanks guys... that was exactly what i was thinking...there is no blower in this slants future |
| Page 2 of 2 | All times are UTC-07:00 |
