It is currently Wed Nov 25, 2026 12:55 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Tue Apr 18, 2006 8:09 am
I tried www.car-part.com and turned up only one 8 1/4 rear with 2.71 gears. Found a bunch of small bolt pattern 7 1/4 rears, but they won't fit my application. Can you swap small bolt pattern axles for big bolt pattern axles?
I don't think so. I mistakenly bought a big bolt pattern 7 1/4" axle out of a '73-'76 A-body, under the impression that all big bolt pattern axles were 8 1/4". So I tried to salveage something of it by making for less work and swapping the axle shafts instead of the whole axle. They didn't fit in my '66 housing - the shafts were larger and had more splines.
I do not know if the '73-'76 small bolt pattern housing will work - it might.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
