It is currently Mon Nov 23, 2026 9:40 pm
PostPosted: Fri Apr 21, 2006 10:02 pm
Tell us how the paxton works for you. I was thinking of getting one as well.
Thanks,
Cory
-'72 Valiant Sedan, Stock (For Now)
PostPosted: Tue Apr 25, 2006 9:22 pm
Mine chomped a gear in 2 weeks....rebuilt pump. I changed the pump out to a used stock pump...N/P since.
Has anyone experienced a noise associated with the infamous pump gear failure (and if so, please describe)? Is the onset sudden or over several thousand miles? My Duster mill makes a rotational noise that I have been blaming on the timing chain for a while, and it's getting worse. Using a stethescope, it seems to be eminating from the front cover area, but I guess it could be telegraphing up the cam. I've ruled out all of the obvious/easy stuff, i.e. accesories, water pump etc. Noise comes and goes, but it sounds like a chain being dragged across a can. When it comes it stays constant until it goes. Could this be pump related? I'm running, as mentioned, the 264S cam and a stock pump that was replaced before I owned the car, probably a Melling.
D/W
If it ain't broke, fix it!
PostPosted: Wed Apr 26, 2006 3:25 pm
Mine made no noise when it sheared at Mach 3....
Chain dragged acrost a can sounds like a TC to me. Wait till it saws a hole in the cover...
PostPosted: Fri May 05, 2006 10:22 am
If you want the stock off the line feel and the higher lift to give a call to comp cams and they will grind that pattern for you but the price might be kind of high. Im going to call them and find out if the 264s is as big as it gets. Some one on ebay is always selling those cam kits for /6 buy now or best offer.
