| Aluminum Head https://slantsix.org/forum/viewtopic.php?t=17323 |
Page 2 of 8 |
| Author: | gmader [ Thu May 04, 2006 4:20 pm ] |
The combustion chamber has to be closed. Yeah, it may bump up the CR. Downside -
Another thing to keep in mind is that Aluminum heads generally can go with a higher CR, due to the better head transfer. Some people point at this, and suggest that Iron heads are more thermally efficient, wasting less of the heat energy into transfer. My $0.02. Greg |
| Author: | SlantSixDan [ Thu May 04, 2006 5:08 pm ] |
Quote: If designed properly
That there is a very, very big "if". Combustion chamber configuration has an enormous impact on detonation resistance, driveability, emissions, power and fuel economy...in other words, every possible reason someone might use a non-stock head! Guessing at combustion chamber shape would be a waste. If there is no money for direct development of a combustion chamber (and, let's face it, unless one of us wins the lottery...there isn't!), then our best bet is to find an existing good combustion chamber of the correct size and valve placement and copy it exactly. Downsizing or upsizing something else (e.g. the Jeep chamber) would be tricky to get right, and very much unguaranteed, since combustion refuses to behave the same in a smaller version of a given chamber as it does in a bigger version and vice versa.Maybe the "fast burn" chamber, already worked out by Chrysler for the slant-6 (just never put into series production, though we know from the '85-'89 318 heads that the concept works well) and known to exist in a couple of slant-6 heads that are floating around in the real world, would be the one to go for. Sure, it's only late-'70s technology, but that's a whole lot better than the late-'50s combustion chamber technology we're running now! |
| Author: | AndyZ [ Thu May 04, 2006 7:42 pm ] |
| Author: | Dart270 [ Fri May 05, 2006 6:19 am ] |
My experience (and I believe many others too) is that head flow on a Slant is a much bigger deal than chamber design. People have made as much as 350 crank HP with the stock chamber design. Optimal ignition timing advance (28-30 deg total) is already way lower than that needed for big bore motors (V8s, etc, are 32-38 total). Detonation seems to be less of a problem than with V8s too. I've run 11:1+ on 92 octane with no destructive effects for many 10ks of miles. That's with the earliest head chamber (67-down), too. I'm not advocating forgetting about chamber design, but holding up the process to design the "ultimate" chamber may not be necessary. Compared to most V8s, the Slant already has a very small combustion chamber. Someone who has welded and reworked the combustion chamber design is Mark Goodman (Team Green Lancer and Valiant). Seymour Pederson has pictures of his work, I believe. Seymour can only be reached over the phone (see "racing" page on ss.org homepage for his number/address). Lou |
| Author: | zedpapa [ Fri May 05, 2006 7:46 pm ] |
i agree that the chamber basically needs to be designed from scratch to work properly. the closed chamber is something that will probably happen. using this head would probably require custom pistons to cope with the added compression and power that results. i know the program my friend has does stress testing but i don't know about checking chamber design testing. again more research is needed here. i am open to all suggestions anyone may have. zedpapa |
| Author: | Team Green [ Sat May 06, 2006 10:23 pm ] |
Could the head be made open chamber with a deck thick enough to mill down to make it closed chamber? Taking all stock bolt on stuff sounds good. The raised ports sound great. Let me know when they ready to ship. |
| Author: | zedpapa [ Sun May 07, 2006 3:20 pm ] |
that is possible and probably a good idea. it might make the head applicable to more people(turbo, NA). it would also help with keeping compression under control. it would still allow bringing compression up if wanted. that will be something that will be taken into consideration. keep the ideas coming and input coming. we have yet to put a design on paper. we are still trying to get the details worked out. zedpapa |
| Author: | Dart270 [ Sun May 07, 2006 6:07 pm ] |
I had a visit today from "gearhead" (Karl) who has been living in Charlotte and is moving back to Porland, OR next week. One of his ideas is to move the intake valve over about 0.040 toward the exh valve (valve guide replacement). This would allow a bigger int valve with less shrouding, since the int side could use more flow help than the exh side. You would run something like 1.80-1.88 int and 1.40-1.46 exh. This would take mimimal adjustment to the rocker arm placement - just a different set of shims along rocker shaft. Lou |
| Author: | Joshie225 [ Sun May 07, 2006 9:02 pm ] |
Interesting. 2 valve engines have, little by little, been moving toward smaller exhaust and larger intake valves for years. Any thoughts on reconfiguring the combustion chamber at the same time? I have some ideas, but I need an engine with zero deck pistons. The problem with going zero deck on a 225 is the compression ends up over 10:1 with a .040" thick gasket and 60cc chamber. If the chamber is done right 10:1 shouldn't be a problem. I know it sounds radical, but there are cars running with aluminum 4 valve heads and special pistons running over 13:1 on pump premium. Heck, new Toyotas and Hondas are running 10.5:1 (advertised) on regular. Actually, if I had it my way, the slant 6 chamber would end up smaller and the piston would have a dish. Coming up with the time and money for the experiments are something else all together. P.S. I wouldn't mind meeting Karl. Pass on my e-mail if you don't mind and we can get together once he's local again. |
| Author: | slantzilla [ Sun May 07, 2006 9:13 pm ] |
Mine now is at 11-1. I raced it on 89 octane opening day. |
| Author: | Joshie225 [ Sun May 07, 2006 9:52 pm ] |
Quote: Mine now is at 11-1. I raced it on 89 octane opening day.
Cool! Got any pictures of the combustion chamber?
| Author: | slantzilla [ Mon May 08, 2006 3:39 am ] |
Quote: Quote: Mine now is at 11-1. I raced it on 89 octane opening day.
Cool! Got any pictures of the combustion chamber? |
| Author: | sick6 [ Mon May 08, 2006 3:18 pm ] |
| Post subject: | a break from buying the house (pulling my hair out) |
Quote: I had a visit today from "gearhead" (Karl) who has been living in Charlotte and is moving back to Porland, OR next week.
right now, I am running 1.88 intake and a 1.5 exhaust with a 75 head.One of his ideas is to move the intake valve over about 0.040 toward the exh valve (valve guide replacement). This would allow a bigger int valve with less shrouding, since the int side could use more flow help than the exh side. You would run something like 1.80-1.88 int and 1.40-1.46 exh. This would take mimimal adjustment to the rocker arm placement - just a different set of shims along rocker shaft. Lou ![]() and here are my flow numbers: ![]() this cost me $800 about six years ago. new valves (duh), guides, full port and polish, 3 angle valve job and milled .090. engine was bored .060 over and milled .065 which gives me 10.4 to 1 comp. my point is to make a cost to gain comparison, not to start any arguments, just for feasibility, to give an example to show folks to compare ideas. I will leave you fine folks to decide if you feel it was worth it or not, but I have to go back to strangling my realtor. I just came on here for a much needed break. |
| Author: | RossKinder [ Mon May 08, 2006 4:10 pm ] |
Quote: Could the head be made open chamber with a deck thick enough to mill down to make it closed chamber? Taking all stock bolt on stuff sounds good. The raised ports sound great. Let me know when they ready to ship.
Exactly what do open chamber and closed chamber mean?
| Author: | Dart270 [ Mon May 08, 2006 5:29 pm ] |
Sick6, Just so you know, you got a SCREAMING deal on that head. If you walked into a speed/machine shop today, they would charge you at least $1500 for those flow numbers and headwork, more like $2000. Lou |
| Page 2 of 8 | All times are UTC-08:00 |
