It is currently Wed Nov 25, 2026 3:27 am
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
PostPosted: Tue May 09, 2006 8:47 pm
...I might have missed something somewhere along the way, but no one ever seems to take into consideration fuel slosh when discussing the pros and cons of an east-west vs. a north-south carburetor
orientation.
Oh, heck, that's easy. If your car stalls when you stop short, you've got a Carter BBS or BBD or other carb with a front- or rear-hung float. If your car stalls when you make a hard left or right turn, you've got a Holley 1920 or other carb with a side-hung float. :shock:
So a Carter is perfect if you have 9" drum brakes all around...........
you don't have to worry about the stalling.................
PostPosted: Tue May 09, 2006 9:33 pm
Ross,
Having the carburetor's throttle shaft parallel with the crankshaft helps even out wet flow fuel distribution. With the carb mounted perpendicular to the crank you get wet flow off the throttle plates towards the rear of the engine. With the parallel throttle shaft the wet flow is more evenly distributed end-to-end. When I ran a 4bbl on a Clifford intake I mounted the carb with the primaries toward the left for this very reason. Pontiac did the same on their 4bbl OHC sixes. My end cylinders ran leaner (or was it richer? It's been a while.) than the center cylinders. Most folks with the primaries towards the front have lean front cylinders. I think a Hyper Pak intake would be less sensitive to carb orientation than the Clifford as the direction of flow within the manifold is more similar between the cylinders. The Clifford intake's end cylinders run fore and aft before turning toward the head and the center cylinders have a straighter shot. This difference in runners is much less pronounced on the Hyper Pak intake.
If you can get fuel distribution equal you can run leaner mixtures and get better economy before hitting lean missfire. My Clifford 4bbl combo would get a little bit of lean misfire on cold nights so I had to richen it up a bit. That's one big penalty of an unheated intake. Lean is ok at light load until you get misfire then the economy goes down the toilet.
So I vote for having the throttle shaft parallel to the crank.
OK, thanks. Me being carburetor illiterate it didn't occur to me that the orientation of the actual holes in the manifold would be incidental to butterfly orientation. Thanks.
PostPosted: Tue May 09, 2006 9:59 pm
Yes, with a factory 2 bbl intake and single throttle shaft carb the throttle shaft is perpendicular to the crank centerline, but a Weber 2 bbl with two throttle shafts those shafts end up parallel with the crank. Too bad Weber 38 DGES carbs are $400. They work well on Jeep 6s. If they were cheaper I'd have to try one. I did run a Holley/Weber 5200 once, but it was a too small and had a nasty hesitation if I hit the gas too fast. I had to drill out the idle jet so my warmed up 225 would even idle with that carb. Drilling the accelerator pump nozzle might have fixed the hesitation. I never found out though as I put my Holley 390 back on the car and ended up with more low end torque than the little 2bbl gave. I think the lesson here is that a lot of recalibration is to be expected when you use a carb from a 2.3 liter smog engine on a warmed over 3.7 liter.
PostPosted: Tue May 09, 2006 10:10 pm
Ok now I'm confused.
The super-six intake manifold had the holes perpendicular to the crank......
What 2-bbl manifold had them parallel????????
PostPosted: Wed May 10, 2006 3:50 am
I'm pretty sure you can rig a 2-bbl Clifford in that way, since it has a bolt-on carb adapter with a square bolt pattern.
One set of factory notes before the Super Six came out suggested cutting and welding a single barrel manifold so that you can put a BBD on that, same orientation.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Wed May 10, 2006 6:51 am
orientation.
Dan, cute, but I think you missed my point. You're right, the float and inlet mounting would have an effect, too, but I'm more concerned about covering/uncovering (or leaning, at the least) the main jets when turning certain carbs so that the throttle shaft runs parallel with the crankshaft. It is my belief that they were designed not designed to operate in that orientation. I realize it's really more a function of bowl/inlet orientation than it is throttle shaft. If one compares a BBS/1920 to a BBD, they will notice that the shafts are oriented differently, but the bowls both point front.
D/W
If it ain't broke, fix it!
PostPosted: Wed May 10, 2006 8:19 am
Oh, OK, gotchya, you're talking about what would happen if e.g. you took a 1920 or BBS and turned it 90 degrees so the bowl faced leftward or rightward. Under hard turns, you could have the fuel slosh away from the jet and starve out the engine.
PostPosted: Wed May 10, 2006 8:41 am
Actually, I was thinking if you nailed it, you might uncover the forward jet...
D/W
PostPosted: Wed May 10, 2006 10:17 am
H'mm. I can see that happening on a BBS, BBD or 1920 if you turned it 180° so the fuel bowl faced rearward. On the BB carbs, the effect would be especially pronounced because the acceleration would also tend to lock the float in the up/no-flow position.
PostPosted: Wed May 10, 2006 10:24 am
I'm thinking 90°. So far, I haven't heard anyone propose turning them around backwards...
D/W
PostPosted: Wed May 10, 2006 11:00 am
OK, well, when I think about turning any of the common slant-6 carbs 90°, let's see here...thinking about a BBD...just based on where the jet is, I'm thinking you could probably get away with it without too much in the way of problems when turning or stopping. A BBD installed such that the bowl faced leftward or rightward would approximate the spatial relations of a Holley 1920 installed bowl-forward as intended.
Or am I still missing your point?
PostPosted: Wed May 10, 2006 11:04 am
The jets, man, the jets...
D/W
