| Rebuilding motor, and super six it https://slantsix.org/forum/viewtopic.php?t=17703 |
Page 2 of 2 |
| Author: | slantvaliant [ Thu May 25, 2006 8:48 am ] |
Quote: 3) deck the block 100 thou (these crazy 6s have a super low 8.4:1 compresson ration that needs to be brought up.)
You might want to check your particular engine before taking off that much anywhere. There is a lot of variation in chamber size, head gasket thickness, etc. Has the deck or head been machined before? A cleanup pass on the head will take up some of that, and a pass on the block a little more.It would be easy to mill yourself into a higher octane fuel requirement, something a daily driver doesn't need. By the way, it wasn't just sixes of the era that had low compression ratios. There are lots of four-bangers and bent-eights with similar numbers. |
| Page 2 of 2 | All times are UTC-07:00 |
