BANG! ...oh...oh no...
https://slantsix.org/forum/viewtopic.php?t=18165
Page 2 of 2
Author:  74.swinger [ Thu Jun 29, 2006 4:20 am ]
:D :D
everything in life should be 'quick and easy'! :roll: :wink:
What was her name again :lol: :lol: :lol:
________
Toyota tz engine specifications
________
Maryjane
Author:  440_Magnum [ Fri Jun 30, 2006 1:05 pm ]
Post subject:  Re: See The Amazing Doctor Dodge!
Doc, you're like the Kreskin of automotive repair. It appears that the rubber gasket that I put at the base of the distributor was entirely too thick. Upon close inspection of the dist. drive gear, I found that the bottom third was missing 3 teeth. So, I had to go ALL the way to the trunk of the car to get my spare dizzy, bolted it in, and the car started right up. Simple. I guess the huge backfire and loss of all power at highway speed just frightened me into throwing Occam's Razor right out the window and expect the worse.
Thank's for all the help!
-josh
What about that "almost pegged" temp gauge? Or did it do that when you turned the ignition back on after having it off for a few minutes (normal gauge behavior unless you have an electronic instrument cluster regulator installed).
Author:  Josh [ Fri Jun 30, 2006 3:22 pm ]
I checked the temp after I had pulled over and put it on acc.
Most likely it was as you mentioned, since I drove it around after I got it running again, and the temp was fine.
-josh
Page 2 of 2 All times are UTC-07:00
