| Slant Six Cranks https://slantsix.org/forum/viewtopic.php?t=18255 |
Page 2 of 2 |
| Author: | Charrlie_S [ Mon Jul 03, 2006 2:51 am ] |
Quote: :?The machine shop botched the job and tried to fit the block with a cast crank (and different bearings). The engine bore technician told me last week there was some problem with fitting the bearings (which had to be reordered), .
As stated before, It is not possible to fit a cast crank/bearings into a forged crank block. The connecting rods are different, also. It was more likely, a preliminary inspection, indicated the crank needed to be turned "X" thousand, and the proper beaing for that size were ordered. When the crank was ground at the crank shop, it was found to need a different size bearing, so new ones needed to be ordered. Or possibly the bearings that were ordered, were found to have a problem (wrong size in the box).
| Author: | Joshie225 [ Mon Jul 03, 2006 7:13 am ] |
One more time since it doesn't seem to be sinking in. You cannot fit a cast crank into that block. The main bearings are wider on the forged crank block and will not allow the cast crank to drop in. Quote: |
| Author: | blake lewis [ Mon Jul 03, 2006 7:35 am ] |
OK, I think I got the point. The rebuilder just told me the crank was forged, not cast. He's still got the cast bearings from the kit in the box. What is still puzzling me though, is why are there foundry spots on the bottom "flanges" of the crank - is this just a different casting process used with this crank that may be due to the "BH" designation of the motor (instead of the "BF" on my '72 block)? |
| Author: | sandy in BC [ Mon Jul 03, 2006 8:51 am ] |
I dont know a whole lot about cranks....but I wont let that stop me from mouthing off. forged cranks will have marks or little flanges from the forging process. A large chunk of metal is literally pounded into the shape of a crank then the journals are machined. This pounding is done in big freekin dies in a number of steps....some pound marks or squish flanges are normal. Dont read to much into the BF or BH marks on the block,,,,BH is a good block that requires a forged crank,,,,,I have one in my car. When they did the crank in my car they ordered new bearings....for a cast crank. The bearings had to be reordered which took some time. I think you are encountering the normal insurmountable difficulties one finds when dealing with an ancient motor in a modern machine shop. If the guys are good it will all work out. BH block= forged crank with attendant rods and bearings. |
| Author: | blake lewis [ Mon Jul 03, 2006 10:05 am ] |
| Author: | sandy in BC [ Mon Jul 03, 2006 10:41 am ] |
Its a waste when it sits in the driveway for weeks at a time while I work. Some people think I destroyed the car with the mods Ive done.\\\ Its not as sweet as you think.. It is a class winner in the Pro-Beater category. |
| Page 2 of 2 | All times are UTC-07:00 |
