| Lights gone out. https://slantsix.org/forum/viewtopic.php?t=18329 |
Page 2 of 2 |
| Author: | SlantSixDan [ Wed Jul 16, 2008 10:34 am ] |
Quote: The new switch is on! I got lights again! They are a little sketchy though. When I turn the knob to dim the intrument panel light, or turn on the light in the roof the headlight can sometimes come and go. I put every wire back on the new switch really carefully and think they have good connection. Any idea?
My first guess is that some of your wires are damaged and will need to be repaired. Also, is this a new switch or a used one from another car?
| Author: | trebor75 [ Thu Jul 17, 2008 1:15 am ] |
Quote: Quote: The new switch is on! I got lights again! They are a little sketchy though. When I turn the knob to dim the intrument panel light, or turn on the light in the roof the headlight can sometimes come and go. I put every wire back on the new switch really carefully and think they have good connection. Any idea?
My first guess is that some of your wires are damaged and will need to be repaired. Also, is this a new switch or a used one from another car?I could however only see that much of the wires coming out from under the dash. it's so tight under there. But what I did see looked good. I guess they continue up under the dash into the firewall? They might very well be damaged there. |
| Page 2 of 2 | All times are UTC-07:00 |
