Octane Booster
https://slantsix.org/forum/viewtopic.php?t=19710
Page 2 of 2
Author:  Eric W [ Fri Sep 15, 2006 9:18 pm ]
P.S. you can ignore me if you like. The internets a big place. My donations can go elsewhere.
Um, uh, ok.
Author:  Tom Drake [ Sat Sep 16, 2006 5:10 am ]
This should answer your questions.
The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting.
The compression ratio of your engine determines the octane rating of the gas you must use in the car. One way to increase the horsepower of an engine of a given displacement is to increase its compression ratio. So a "high-performance engine" has a higher compression ratio and requires higher-octane fuel. The advantage of a high compression ratio is that it gives your engine a higher horsepower rating for a given engine weight -- that is what makes the engine "high performance." The disadvantage is that the gasoline for your engine costs more.
The name "octane" comes from the following fact: When you take crude oil and "crack" it in a refinery, you end up getting hydrocarbon chains of different lengths. These different chain lengths can then be separated from each other and blended to form different fuels. For example, you may have heard of methane, propane and butane. All three of them are hydrocarbons. Methane has just a single carbon atom. Propane has three carbon atoms chained together. Butane has four carbon atoms chained together. Pentane has five, hexane has six, heptane has seven and octane has eight carbons chained together.
It turns out that heptane handles compression very poorly. Compress it just a little and it ignites spontaneously. Octane handles compression very well -- you can compress it a lot and nothing happens. Eighty-seven-octane gasoline is gasoline that contains 87-percent octane and 13-percent heptane (or some other combination of fuels that has the same performance of the 87/13 combination of octane/heptane). It spontaneously ignites at a given compression level, and can only be used in engines that do not exceed that compression ratio.
During WWI, it was discovered that you can add a chemical called tetraethyl lead (TEL) to gasoline and significantly improve its octane rating above the octane/heptane combination. Cheaper grades of gasoline could be made usable by adding TEL. This led to the widespread use of "ethyl" or "leaded" gasoline. Unfortunately, the side effects of adding lead to gasoline are:
Lead clogs a catalytic converter and renders it inoperable within minutes.
The Earth became covered in a thin layer of lead, and lead is toxic to many living things (including humans).
When lead was banned, gasoline got more expensive because refineries could not boost the octane ratings of cheaper grades any more. Airplanes are still allowed to use leaded gasoline (known as AvGas), and octane ratings of 100 or more are commonly used in super-high-performance piston airplane engines. In the case of AvGas, 100 is the gasoline's performance rating, not the percentage of actual octane in the gas. The addition of TEL boosts the compression level of the gasoline -- it doesn't add more octane.Currently engineers are trying to develop airplane engines that can use unleaded gasoline. Jet engines burn kerosene, by the way.
Author:  tophat [ Sun Sep 17, 2006 8:25 am ]
Tom, that is the first explanation that has made sense, ever, on that topic :D
There are alot of myths, misinformation, and just good ole BS on this subject.
thanks for making it understandable
tophat
Author:  Dart270 [ Sun Sep 17, 2006 5:28 pm ]
From what I have heard, most octane boosters are not very effective, but I have heard that Torco fuel additives DO live up to their ads. This is a guy with Slant 6s and lots of dyno experience.
Page 2 of 2 All times are UTC-07:00
