Slant Six Forum https://slantsix.org/forum/ |
Supercharger https://slantsix.org/forum/viewtopic.php?t=19732 |
Page 2 of 3 |
Author: | sandy in BC [ Wed Sep 20, 2006 7:15 pm ] |
Post subject: | |
Ah,,,,the 11 second barrier...... |
Author: | Avenger2040 [ Wed Sep 20, 2006 7:19 pm ] |
Post subject: | |
mmmm......looks like this project will be more costly than I thought, I can get a TBird supercharger for 80 dollars (is working well), but the blow-through carb will be a real problem to get here. |
Author: | CStryker [ Wed Sep 20, 2006 7:39 pm ] |
Post subject: | |
If you're willing to go the four barrel route (and can get a holley relatively cheaply), there's instructions all over the net for how to rig them up to work as blow through. It doesn't look like that bad of a process. |
Author: | AndyZ [ Thu Sep 21, 2006 11:57 am ] |
Post subject: | |
Quote: mmmm......looks like this project will be more costly than I thought, I can get a TBird supercharger for 80 dollars (is working well), but the blow-through carb will be a real problem to get here.
You can always go with a draw through on a roots type blower. The expensive and /or time consuming part of installing any blower on a slant is custom made parts (pulley, bracket, etc).
Author: | slantzilla [ Thu Sep 21, 2006 12:08 pm ] |
Post subject: | |
Quote: Ah,,,,the 11 second barrier......
It ain't as easy as it looks on paper.
Author: | Charrlie_S [ Thu Sep 21, 2006 1:06 pm ] |
Post subject: | |
Quote: Quote: Ah,,,,the 11 second barrier......
It ain't as easy as it looks on paper. |
Author: | slantzilla [ Thu Sep 21, 2006 2:16 pm ] |
Post subject: | |
Author: | sandy in BC [ Thu Sep 21, 2006 2:51 pm ] |
Post subject: | |
Add fuel and oxygen until piston melts ....then back off 2 steps. Repeat as necessary. |
Post subject: | |
Add fuel and oxygen until piston melts ....then back off 2 steps. Repeat as necessary.........Looks easy to me.... |
Author: | slantzilla [ Thu Sep 21, 2006 5:08 pm ] |
Post subject: | |
Quote: Add fuel and oxygen until piston melts ....then back off 2 steps. Repeat as necessary.........Looks easy to me....
Wanna bankroll my next attempt tough guy?
Author: | Avenger2040 [ Thu Sep 21, 2006 9:01 pm ] |
Post subject: | |
Tell me the truth, is worth the time and money to supercharge/turbocharge a slant? supercharge my slant is hitting the 400 dollars mark and can go up to 600 dollars, while putting a 360 V8 with anything to make it run cost me 420 dollars. Also I need the hood to close well or with a small scoop (no more than 2 inches tall), currently my car is parked in the street so is not a good idea to make it to attractive to certain eyes. |
Author: | vynn3 [ Fri Sep 22, 2006 5:37 am ] |
Post subject: | |
Quote: Tell me the truth, is worth the time and money to supercharge/turbocharge a slant? supercharge my slant is hitting the 400 dollars mark and can go up to 600 dollars, while putting a 360 V8 with anything to make it run cost me 420 dollars.
What is your goal? If your intention is to go as fast as possible with the smallest initial financial investment, then yes, you should swap in the 360.
Author: | Avenger2040 [ Fri Sep 22, 2006 8:10 am ] |
Post subject: | |
My goal is speed and mileage, the best of both for a street car in a country with no car mod laws. |
Author: | vynn3 [ Fri Sep 22, 2006 9:31 am ] |
Post subject: | |
Quote: My goal is speed and mileage, the best of both for a street car in a country with no car mod laws.
Then I would suggest a blown slant or a small V-8 (273 or 318), not a 360.
Author: | AndyZ [ Fri Sep 22, 2006 9:46 am ] |
Post subject: | |
Turbo is probably cheaper than a supercharger to get and make work on a slant. I have never done a turbo slant, and for that matter completed a blower on a slant...yet. If you are in love with the slant, keep it and make it run like you want it to. V8 conversion is the easiest for a power increase since pre-made parts are available to complete the conversion. Since this is the "Slant 6" site, I personally would turbo the slant.
Page 2 of 3 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
