| Calling Doc, Oil Pump Gear Oiling https://slantsix.org/forum/viewtopic.php?t=20113 |
Page 2 of 2 |
| Author: | valiantboy_66 [ Sun Oct 15, 2006 10:35 am ] |
Doc thanks for the picture it really clears things up. The tube in the picture looks like brass fuel line for model airplanes. I have some of this and it is a lot stiffer than the copper oil gauge tube, it just kinks easier in tight radiuses. I will try making one with that. If I cant get a new/rebuilt six hole oil pump what is the rebuild kit part number? |
| Author: | Doctor Dodge [ Mon Oct 16, 2006 4:48 am ] |
Quote: ... The tube in the picture looks like brass fuel line for model airplanes... Any small, stiff wall tube will work. the copper tubing can be used if you solder on a stiffing plate to reinforce it. Quote: ...
Melling K66A for the 5/8 thick impeller size.If I can't get a new/rebuilt six hole oil pump what is the rebuild kit's part number? DD |
| Author: | valiantboy_66 [ Mon Oct 16, 2006 6:55 pm ] |
Well I had the local parts store look up the oil pump. No six bolt pumps available. He tried Melling and Fed Mog, nothing, all five bolters. |
| Author: | Doc [ Tue Oct 17, 2006 11:08 am ] |
Just watch out for impeller thickness differences, most 5 hole pumps use the 7/8 thick impeller. DD |
| Author: | valiantboy_66 [ Tue Oct 17, 2006 11:06 pm ] |
Thanks Doug. I'll double chech. |
| Author: | Bren67Cuda904 [ Sat Jan 27, 2007 7:02 pm ] |
If I am reading this thread correctly, one can not spray oil directly in to the oil pump gears without a 6 bolt pump. Is this correct? The pump I have is a 7/8 Melling pump. |
| Author: | Doctor Dodge [ Sat Jan 27, 2007 7:14 pm ] |
Yes, 6 bolt pumps have 3 sealed pockets, the unused "third pocket" will be used to mount the spray tube and channel oil pressure to. 5 bolt pumps only have 2 sealed pockets so they will not support this mod. DD
| Author: | Bren67Cuda904 [ Sun Jan 28, 2007 9:09 am ] |
Quote: Yes, 6 bolt pumps have 3 sealed pockets, the unused "third pocket" will be used to mount the spray tube and channel oil pressure to.
I understand that with out the 6 bolt pump the mod pictured can not be done, but is there some other place I can tap into the spray oil onto the gear?
5 bolt pumps only have 2 sealed pockets so they will not support this mod. DD |
| Author: | CStryker [ Tue Jan 30, 2007 5:48 pm ] |
On my block, there isn't even a pocket for the six hole pump to mount up with (there was some casting flash, which I ground off. Looking at it, I'd say you should be able to drill the hole and plumb it with an external oil line fed from a standard five bolt pump. Maybe the pictures will explain what I mean a little more clearly: Before ![]() After
| Author: | StrokerScamp [ Sun Jul 18, 2021 4:28 am ] |
| Post subject: | Re: Calling Doc, Oil Pump Gear Oiling |
Can we get the pictures reposted on this please? They seem to be unhosted now. Thank you. |
| Author: | StrokerScamp [ Sun Jul 18, 2021 8:26 am ] |
Quote: Can we get the pictures reposted on this please? They seem to be unhosted now. Thank you.
Nevermind. I got it figured out.
| Page 2 of 2 | All times are UTC-07:00 |
