Slant Six Forum https://slantsix.org/forum/ |
need some advice on an engine combo https://slantsix.org/forum/viewtopic.php?t=20389 |
Page 2 of 2 |
Author: | Super6 [ Fri Oct 27, 2006 6:37 am ] |
Post subject: | |
Quote: Quote: I can't see how a set of small tube long primary headers will hurt it?
They'll reduce low-end torque and driveability, which is what you want to maximise in a truck application.As to the loss of intake manifold heat: I drove around in Alaska with headers on my slant, and it was never a problem. Warmup may or may not have taken longer, I never timed it. When it is -20*F the truck was going to be running for 15 minutes before I went anywhere anyway. I never had carb icing issues in Alaska, as the humidity was too low (read, usually 0% ). I did have my carb ice up a handful of times in Montana, over the course of three years. But, in those instances, a 3 minute stop at a convenience store for coffee provided enough heat soak to thaw the carb out. $0.02 |
Author: | Slanted Opinion [ Sat Oct 28, 2006 5:02 am ] |
Post subject: | |
On the topic of headers... Do the short tube ones (ala Clifford) provide much benefit, or are they too short to have any tuning value? -Mac |
Page 2 of 2 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
