It is currently Fri Nov 20, 2026 12:32 am
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
PostPosted: Fri Feb 02, 2007 2:41 pm
Looking at my 63 factory manual, your suggestion that I have an orange 17 tooth one is correct. I only have 4 1/2 teeth to reconstruct from, but it looks like 17. That would have been stock for a 225 Valiant with 650-13 tires and 2.93.
PostPosted: Fri Feb 02, 2007 3:53 pm
Sorry for the mis-info, I did not realize you were working with the 60-65 set-up. :oops:
PostPosted: Fri Feb 02, 2007 5:35 pm
My bad.
I didn't know there were more than one type of speedometer pinion.
Here's the type I have:
PostPosted: Fri Feb 02, 2007 5:40 pm
My bad.
All I see is a tiny blurry unreadable picture..............
PostPosted: Fri Feb 02, 2007 6:09 pm
I think there's something wrong with your monitor. :wink:
OK. You can say it.
This type was only used in 1963, right?
Oh, well.
I still have my tachometer 8)
PostPosted: Fri Feb 02, 2007 7:08 pm
OK. You can say it.
Same pictures were used in the 65 manual, so you're safe...........
:wink:
PostPosted: Fri Feb 02, 2007 7:42 pm
So this setup was used 60-65?
My FSM says that a 6-cyl Savoy/Belvedere/Fury had a brown 16-tooth gear in 1963.
I wonder what other models/years.
What models have a 16-tooth gear in 1965?
PostPosted: Fri Feb 02, 2007 7:55 pm
The 65 manual cross-references the pinion gears by transmission type,rear-end ratio and tire size................. (no mention of model)
PostPosted: Fri Feb 02, 2007 9:34 pm
If I have to get a whole speedometer cable to get the gear, I will look for a 16-tooth one for a TP-1 (6-cyl Savoy, Belvedere, Fury).
Can I use a cable from a Belvedere, or are there differences at the firewall or speedometer?
63 Signet / 10 inch front drums / weber 2bbl / HEI / 2.76 rear end
