| Speedometer gear for 2.76 29? https://slantsix.org/forum/viewtopic.php?t=21700 |
Page 2 of 2 |
| Author: | sixsignet [ Fri Feb 02, 2007 2:41 pm ] |
Looking at my 63 factory manual, your suggestion that I have an orange 17 tooth one is correct. I only have 4 1/2 teeth to reconstruct from, but it looks like 17. That would have been stock for a 225 Valiant with 650-13 tires and 2.93. |
| Author: | Doc [ Fri Feb 02, 2007 3:53 pm ] |
Sorry for the mis-info, I did not realize you were working with the 60-65 set-up. DD |
| Author: | sixsignet [ Fri Feb 02, 2007 5:35 pm ] |
My bad. I didn't know there were more than one type of speedometer pinion. Here's the type I have: |
| Author: | emsvitil [ Fri Feb 02, 2007 5:40 pm ] |
Quote: My bad.
All I see is a tiny blurry unreadable picture..............
I didn't know there were more than one type of speedometer pinion. Here's the type I have: ![]() |
| Author: | sixsignet [ Fri Feb 02, 2007 6:09 pm ] |
I think there's something wrong with your monitor. ![]() OK. You can say it. This type was only used in 1963, right? Oh, well. I still have my tachometer |
| Author: | emsvitil [ Fri Feb 02, 2007 7:08 pm ] |
Quote: ![]() OK. You can say it. This type was only used in 1963, right? Same pictures were used in the 65 manual, so you're safe........... |
| Author: | sixsignet [ Fri Feb 02, 2007 7:42 pm ] |
Quote: Sorry for the mis-info, I did not realize you were working with the 60-65 set-up.
So this setup was used 60-65?DD My FSM says that a 6-cyl Savoy/Belvedere/Fury had a brown 16-tooth gear in 1963. I wonder what other models/years. What models have a 16-tooth gear in 1965? |
| Author: | emsvitil [ Fri Feb 02, 2007 7:55 pm ] |
The 65 manual cross-references the pinion gears by transmission type,rear-end ratio and tire size................. (no mention of model) |
| Author: | sixsignet [ Fri Feb 02, 2007 9:34 pm ] |
If I have to get a whole speedometer cable to get the gear, I will look for a 16-tooth one for a TP-1 (6-cyl Savoy, Belvedere, Fury). Can I use a cable from a Belvedere, or are there differences at the firewall or speedometer?
| Page 2 of 2 | All times are UTC-07:00 |
