Wiper Switches
https://slantsix.org/forum/viewtopic.php?t=22061
Page 2 of 2
Author:  mopar_nocar [ Sun Mar 11, 2007 8:51 pm ]
Post subject:  thanks
good deal.
sb
Author:  dakight [ Mon Mar 12, 2007 7:26 pm ]
Post subject:  Re: interchange
so what year wiper switch will interchange? i need one for my 65 Cuda.
If you have electric squirters, '65-'66 Dart, Valiant, Barracuda wiper switches should be the same (single or variable speed). If you have pedal-pusher squirters (or none at all), then '63-'66 Dart, Valiant, Barracuda switches ought to be workable. There is this new switch available from NAPA as Echlin WSWS6456, listed for "1962 Chrysler":
Looks like a single-speed wiper switch to me, might or might not be the right diameter and/or stem length for other applications.
This is the animal I'm dealing with:
The neck of the switch is 2 inches in length from the housing to the end of the threaded portion. I think I'm out of luck finding one with an integrated washer switch.
Author:  SlantSixDan [ Mon Mar 12, 2007 7:54 pm ]
That's a variable-speed wiper switch. I'd just be guessing, but maybe something from a '64-'65-'66-'67-'68-or-other-year Chrysler or Imperial might have similar dimensions and an inbuilt washer switch. I really think a separate pushbutton is going to be your easiest bet, eh?
Author:  dakight [ Tue Mar 13, 2007 5:14 am ]
Yep. That's pretty much the conclusion I've reached. I'm going to look into mounting something on the floor where the rubber bulb was. If I can't figure out how to do that it will be a switch on the dash but I don't want it to look cheesy.
Page 2 of 2 All times are UTC-08:00
