compression ratio calculators
https://slantsix.org/forum/viewtopic.php?t=22942
Page 2 of 2
Author:  slantfin [ Sat May 19, 2007 3:08 pm ]
Post subject:  fabled land of 110
What state is that 1969ronnie ? My cars are asking if we can move there.
Author:  Doc [ Mon May 21, 2007 10:16 am ]
There is no reason to use a domed piston in a 225 SL6.
Note: The domed pistons in the H-Pak kit were designed for the "zero deck" 170 and just happened to also fit into a 225, so they were used there.
Honestly, today's 'hot combo" for a high performance / high compression tall block SL6 is based on around the 198 con rod and 2.2 piston design. (long rod engine)
In general, a 225 SL6 with a deck height in the -.045 to -.020 range will get you over 10 to 1 compression with an unmilled cylinder head.
Page 2 of 2 All times are UTC-07:00
