| mpg investigation https://slantsix.org/forum/viewtopic.php?t=23103 |
Page 2 of 2 |
| Author: | Davey [ Wed May 09, 2007 4:51 am ] |
Some in here may know a lot more than I when it comes to rebuild kits, but I got the three kits I used from Carquest because I worked there and knew they had good stuff. All three kits came complete with all the gaskets (with extras where more than one variant of the carb may exist), all the checkballs and springs and accel pump washers etc etc etc. You will get a good quality kit from NAPA also, but I think their prices are a little steeper from what I've seen. I work for them now and I am surprised sometimes by how much higher their stuff is generally. By the way, you will likely have to buy a float seperately, if your carb needs one. None of the kits I bought included the float, but the ones in my carbs were brass and not leaking so I didn't need them. Carquest and NAPA both list seperate part numbers for the floats, so they don't come with the kits. Davey |
| Author: | Aggressive Ted [ Wed May 09, 2007 9:54 am ] |
I prefer buying what I need directly from a carb shop. I have also purchased Hygrade Kits and find them to be ok. I have used a few NAPA kits and they are ok too. |
| Page 2 of 2 | All times are UTC-07:00 |
