Baaad noise!
https://slantsix.org/forum/viewtopic.php?t=23254
Page 2 of 3
Author:  icaneat50eggs [ Wed May 30, 2007 9:02 pm ]
Well there is a 100% chance I will be crawling under the car again tomorrow.
Author:  dakight [ Thu May 31, 2007 5:33 am ]
Have you checked the water pump? And the alternator?
Author:  icaneat50eggs [ Thu May 31, 2007 9:58 pm ]
Yes, I checked them both by removing the belt, same noise.
Author:  skraecken [ Sat Jun 02, 2007 10:09 am ]
Bad wristpin?
Author:  icaneat50eggs [ Sat Jun 02, 2007 10:18 am ]
I have wondered about a wrist pin, would it just go bad like that all of a sudden?
Author:  slantzilla [ Sat Jun 02, 2007 11:11 am ]
I've never heard a wristpin squeal, but they will knock. Maybe one has slid out and is eating a cylinder wall.
You should have seen evidence of that when you pulled the pan though.
A galling rocker will sqeal like crazy, but I've never heard one knock.
Author:  icaneat50eggs [ Sat Jun 02, 2007 11:44 am ]
You guys are going to give me nightmares. Ive got a couple more main bearings to check.
Author:  sandy in BC [ Sat Jun 02, 2007 12:45 pm ]
Hows the crank damper?
Author:  icaneat50eggs [ Sat Jun 02, 2007 12:50 pm ]
Crank damper looks fine, not crooked or anything, I am not sure what to look for regarding it.
Author:  icaneat50eggs [ Mon Jun 04, 2007 7:44 pm ]
In the process of taking the rod end caps off to check bearings, I messed up the bearing tab that keeps the bearing from turning. I need one rod bearing. Is this something I can buy one of? Does anyone on the board have one I could purchase? This is what was on the bearing.....ACL 020 4601 30JL99
Author:  icaneat50eggs [ Mon Jun 04, 2007 9:07 pm ]
Never mind, I just looked at prices on ebay, 11-15$ for a set. Will I have to possibly file the end of the bearings to get the correct fit? I have never replaced a bearing before.
Author:  slantzilla [ Tue Jun 05, 2007 5:08 am ]
Bearings should not be filed. They have to be ordered by the size of the crank. ince your old bearing is stamped 020 I would believe that they are .020" undersize. :shock:
Author:  Charrlie_S [ Tue Jun 05, 2007 5:30 am ]
Send me your mailing addy in a PM. I should have an extra 20 under bearing in a broken set, you can have. I will have to look, later today.
PS: what year is your engine? Is it a cast crank or forged crank? you can measure the width of the bearing with a ruler, and list the width, if you are not sure.
Author:  icaneat50eggs [ Tue Jun 05, 2007 7:33 am ]
I will measure the width today. Thankyou.
Author:  icaneat50eggs [ Sun Jun 10, 2007 12:25 am ]
Well, I pulled all the bearing caps off one at a time, no spun bearings there, I pulled the main bearings off, they were good. While I was laying under the car, crying, I thought...NO, couldnt be that simple. I got a wrench and was able to tighten all 4 bolts that hold the torque converter on the flexplate. Put the pan back on, added oil, started the car. Knocking noise is gone. I know several of you told me to check the bolts, but I was sure the knock was from inside the engine. I almost didnt post this, hopefully it saves one person from having to do what I ended up doing. From now on I will check the bolts. When I add oil, I will check the bolts. When I replace the air freshener, I will check the bolts. Thankyou all for your posts, we shall not speak of this again. :wink:
Page 2 of 3 All times are UTC-07:00
