| practical mpg increases? https://slantsix.org/forum/viewtopic.php?t=23596 |
Page 2 of 2 |
| Author: | DusterIdiot [ Sat Jun 16, 2007 12:06 am ] |
| Post subject: | What at where, when... |
Quote: at idle should i be shooting for as high as possible or?
If you have 30 at just above idle and things are fine, that's ok....what do you get when you run the tach up to 2800 rpm? -D.Idiot |
| Author: | Andy's GT [ Sat Jun 16, 2007 7:00 am ] |
my tach shocks me and doesnt work really |
| Author: | 1970valiantslant6 [ Sat Jun 16, 2007 5:03 pm ] |
| Post subject: | distributor advance |
hey how do i tell what vac advance i have. i seen the stamp on the arm when i installed it. wondering what i bought. i got it off ebay. is there any place on this forum or elsewhere for that info? i did some searchs but i'm not sure what to search. |
| Author: | Aggressive Ted [ Sat Jun 16, 2007 5:24 pm ] |
| Post subject: | Advance? |
Anybody know where you can get a 15 or 16R vacuum advance? THe highest I can find is a 11R advance. If they still exist, where? and what is the part number? Thanks |
| Author: | Sam Powell [ Sat Jun 16, 2007 7:40 pm ] |
You can lengthen the slot in the arm that limits the travel in and out of the pot, with carefull work from a Dremel tool and a cut off disk, and make it any amount you want. Measure the slot, and do some match to figure a proportional amount to lengthen it. Simply slice a little metal out of the arm to lengthen the narrow part a MM or two, what ever the math tells you. Sam |
| Author: | Andy's GT [ Sat Jun 16, 2007 7:53 pm ] |
what is the formula to determine how much to cut out? thanks |
| Author: | dakight [ Sat Jun 16, 2007 7:58 pm ] |
If L1 is the current length and A1 is the current advance let L2 be the new length needed and A2 the desired advance then the formula will be: L2 = L1 X A2 / A1, assuming a linear relationship. |
| Author: | Andy's GT [ Sat Jun 16, 2007 8:22 pm ] |
thanks! |
| Author: | MoparBrit [ Fri Jun 29, 2007 2:49 pm ] |
| Post subject: | Tach |
That tach deal concerns me. Most I've hooked up have had the following wires. Black - earth/ground, Red - positive/hot wire, White - dash lights, Green - trigger wire hooks to neg side of coil. Hope that helps. |
| Page 2 of 2 | All times are UTC-08:00 |
