| Should bother using a Slant 6? https://slantsix.org/forum/viewtopic.php?t=24425 |
Page 2 of 3 |
| Author: | Cherry Grower [ Sat Aug 11, 2007 10:47 am ] |
Well, I did find one more number on the cylinder block. Here's what I have so far: Cylinder block under the most forward spark plug (nothing at the rear): 1 225 R 2 On the engine block under the manifolds: 330-3 On the valve cover is a Chrysler plate with the number: 3735074 Any more suggestions on where else to look? |
| Author: | Cherry Grower [ Sat Aug 11, 2007 11:10 am ] |
Just a bit more about the unit. It's in a cherry harvester made by Orchard Machinery Corporation out of California I think. They bought Dodge pick up front ends and chassis and fabricated the rest to suit. My guess is this one is from the early or mid 70s?
| Author: | icaneat50eggs [ Sat Aug 11, 2007 11:36 am ] |
Watch out for Slantzilla, he will try to get you to run nitrous on that thing |
| Author: | slantzilla [ Sat Aug 11, 2007 12:55 pm ] |
Quote: Watch out for Slantzilla, he will try to get you to run nitrous on that thing
Naw, just trying to help him find parts. A nitrous cherry picker would be cool though. |
| Author: | rock [ Sat Aug 11, 2007 1:23 pm ] |
| Post subject: | Naaah, on ebay that is a RARE, project Dodge |
On Ebaysuch vehicles often appear in the Dodge truck listings as: RARE, Dodge project truck, missing a few parts including cab, runs good, no title, minimum bid $3250 rock '64d100 |
| Author: | SlantSixDan [ Sun Aug 12, 2007 9:01 am ] |
Yup, a '72-design Dodge truck. We're narrowing in on the year of the engine. Pull one of the spark plugs and see whether it uses a gasket seat or a tapered seat (or just tell us what the spark plug number is). |
| Author: | Cherry Grower [ Mon Aug 13, 2007 3:44 pm ] |
Here's the plug: AC Delco R45XLS ![]() I'm pretty sure I'll end up using this engine. Hopefully I'll be able to screw with the carb in the next couple of days. I'm guessing this engine is a 225 cubic inch? I really appreciate the help on identifying this engine! |
| Author: | SlantSixDan [ Mon Aug 13, 2007 4:03 pm ] |
Yep, it's a pre-1975 225. Probably a '72-'74 unit, and that certainly gets you close enough to order parts. There are no mechanical differences in that year range. So...what're your plans? Complete teardown and rebuild? |
| Author: | emsvitil [ Mon Aug 13, 2007 10:11 pm ] |
Looks like the washer is still on the plug...... You need to remove the washers, the tube does the job of the washer. |
| Author: | Cherry Grower [ Tue Aug 14, 2007 5:04 am ] |
Not quite sure about the rebuild yet. I'll get it running properly and see how much blue smoke comes out the exhaust! Probably will do a compression check on each cylinder. What should the compression readings be? |
| Author: | slantzilla [ Tue Aug 14, 2007 5:46 am ] |
I have seen stock Slants run anywhere from 110 to 180 psi. What I look for is an even spread across the board rather than a specific number. Anything above 110 will actually be good enough. |
| Author: | Cherry Grower [ Wed Aug 15, 2007 7:24 pm ] |
Thank you very much gentlemen. Got the carb off today and started cleaning it. Should have the beast running in a few days. |
| Author: | Cherry Grower [ Sun Aug 19, 2007 6:44 pm ] |
Got the carb cleaned today. I went with muriatic acid as nothing else did anything. My cousin suggested the acid. He told me you gotta work quick and have a bucket of water to immerse it in after a few seconds of dipping it in the acid. Worked like a charm. The engine runs decent even without a carb rebuild!! While I run the starter and turn the engine, it sounds like a couple of the valves leak a bit. All in all, it's a pretty promising unit. |
| Author: | slantzilla [ Sun Aug 19, 2007 7:39 pm ] |
Glad to hear you're making progress! |
| Author: | Doctor Dodge [ Sun Aug 19, 2007 8:57 pm ] |
Quote: While I run the starter and turn the engine, it sounds like a couple of the valves leak a bit. All in all, it's a pretty promising unit...
Time to check the valve lash adjustment.DD |
| Page 2 of 3 | All times are UTC-08:00 |
