It is currently Tue Nov 24, 2026 12:32 am
PostPosted: Sun Aug 19, 2007 6:07 pm
Well I think in this case its the Comp cam.....and high rpm shifts. I had a 100000 mile OEM pump with a beauty gear on it.....not HV...
I never wiped out a cam in any way till this year. I killed a Comp cam in my work truck this spring as well.( 3 lobes)
This motor has about 1500 miles on it DI....and its already wiped out 2 pump gears , a crank and a cam. Yood think I had it on a bottle...
Thanks for the cam offer Dennis...Im not sure .510 lift(.340 at cam) is doable with low CR(9.25) and my old chev valve springs. I might preload a rocker 47 thou and see......(currently .440 lift......293 at cam)
The good news was the car top ended like never before.....
PostPosted: Sun Aug 19, 2007 6:22 pm
Sandy
IIRC I saw a post that ERSON has the 270 " on the shelf for 1 day shipment"
It might be the ticket for you.
On a side note if you get to Arkansas we are 18 miles off of I40 @ mile marker 221. 1 hour west of Memphis Tn.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: Another Question...
PostPosted: Thu Aug 23, 2007 6:53 am
Hey Sandy when you tear it down, let me know if you see any evidence of cam walk, I forget if you are running a cam button or not on the timing cover... I'm wondering if this is a fair part of the issue.
PostPosted: Thu Aug 23, 2007 7:15 am
No cam button.
Ill look for cam walk....
Its strikes me as significant that I never did a pump till I cammed it. Having wiped out a Comp cam in my work truck this spring Im not very confident that the Comp cam pump drive gear is not at fault.
I wont have any time to even look at it for a few weeks.....
Users browsing this forum: Amazon [Bot], Bing [Bot] and 7 guests
