It is currently Sat Oct 10, 2026 4:47 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Tue Oct 09, 2007 6:14 pm
Thanks Greg....
But....my adv intake closing is 71
Adv ex dur is 270
Lobe sep is 109....ground 2 deg advanced
Intake opens 29 btdc closes 71 deg
exhaust opens 62 atdc closes 28 deg
overlap 57 advanced 2deg
Bore is 3.466
Total cc is 71 ( I think...)
PostPosted: Tue Oct 09, 2007 7:51 pm
I went by the standard Erson 280 specs, as posted elsewhere. let me run this again for you.
PostPosted: Tue Oct 09, 2007 8:04 pm
Here is the final result, based on what you posted. I zeroed out the amount you are in the hole, as well as the gasket thickness.
Regardless, the calculations are looking a lot different from what you posted from the web based calculator gizmo.
The reason that I am so interested in this is because it appears there is a lot of differences in how this can be calculated. I researched this a lot during the Bren/Eileen timeframe, to better figure out what was real in planning my own engine build.
PostPosted: Wed Oct 10, 2007 4:51 am
Using those same #s on the web based calc I got DCR of 7.84.....
I still think I need to take out about 5-6cc to end up at 10:1 CR and a DCR around 7.75
Im tempted to go to a 62cc /10.5 DCR 8 setup
Out of town till Sat.....
PostPosted: Sat Oct 13, 2007 2:28 pm
Highway time provides room for thought....
I think Lou is suggesting advancing the cam about 6 degrees so the intake closes sooner. This would increase DCR without milling.
Time to run some more numbers......
Users browsing this forum: DuckDuckGo [Bot] and 22 guests
