| which alternator??? https://slantsix.org/forum/viewtopic.php?t=25444 |
Page 2 of 2 |
| Author: | SlantSixDan [ Sun Oct 21, 2007 12:57 pm ] |
| Post subject: | Re: Ammeter.... |
Quote: It gets tricky running the ammeter with higher output alternators........
Yeah, you get to pick either the pre-'70s OE type that works well but has a relatively low current limit before things start burning up, or the post-'70s OE-type that has a high current limit and doesn't work! |
| Author: | Matt Cramer [ Sun Oct 21, 2007 2:21 pm ] |
Quote: Are you going to run an ammeter or voltage gauge?
Ammeter, with a diode shunt. It's trickier still to make a voltmeter look like my original sideways-mounted ammeter.It gets tricky running the ammeter with higher output alternators........ If I were completely redoing my dash, I might consider a voltmeter (or an aftermarket ammeter). But I'm leaving the stock dashboard in at the moment, and don't like the idea of a dead gauge in the dashboard. |
| Author: | SlantSixDan [ Sun Oct 21, 2007 2:24 pm ] |
Quote: I'm leaving the stock dashboard in at the moment, and don't like the idea of a dead gauge in the dashboard.
I approve! |
| Page 2 of 2 | All times are UTC-07:00 |
