| motor plates? https://slantsix.org/forum/viewtopic.php?t=25739 |
Page 2 of 2 |
| Author: | Moparedd [ Mon Jun 09, 2008 10:19 pm ] |
| Post subject: | Re: motor plates? |
Quote: Has anyone gone through the trouble of doing a nice set of CAD'd motor plates for the /6? I'd like to have a motor and mid plate on my open wheel car.
I make motor plates for slant 6. Go to www.pacefabrication.net and check out "Products" and Cars & Projects. See motor plate installation on a slant 6 DemonI'd also like to talk to some of the guys using a dry sump system. Thanks! MoparEdd |
| Author: | Moparedd [ Mon Jun 09, 2008 10:26 pm ] |
Quote: I would like at least one set, possibly two. Let me know when you are ready to make them; when you need $, etc.
Check out this website for pictures and prices. www.pacefabrication.net If any questions...email me moparedd |
| Author: | Moparedd [ Mon Jun 09, 2008 10:31 pm ] |
[quote="sergio"]We are in the process of making several for some west coast sl6 racers,for now only for 225s. We can sell these for $115 lincludes the frame brackets,water pump hole or remote, we are also supplying a bracket that bolts to the alt. bracket bolt holes for additional bracing. If interested see wwwpacefabrication.net |
| Author: | wayne erickson [ Thu Jun 12, 2008 7:11 am ] |
These engine plates are a 'work of art"..if you have ever seen Edd's work (or his new car..Check out his website for start/finish photos) you will know you are getting the best engineered products at a very affordable price. I run one on my new 1962 Valiant and they fit perfect. Go to PACEFABRICATION.NET and check out his slant6 "goodies" |
| Author: | Kidd [ Thu Jun 12, 2008 4:50 pm ] |
I have one on my 62 Valiant.......and love it. It came from Ed. Andrew |
| Author: | Moparedd [ Wed Jun 25, 2008 8:31 pm ] |
Hey Tim...I have motor plates ready for shipping. Do you want one with the water pump provisions or without? see www.pacefabrication.net.or email me mopareddpacefab@aol.com |
| Author: | Moparedd [ Wed Jun 25, 2008 8:37 pm ] |
Quote: We can make them any time,allow about 10 days for delivery,we need a little info about the chassis. Prymarily the crank centerline as it relates to your chassis,and if you have moved the engine around or a chassis car frame rail width,etc. If interested call the # listed above to find otu any other pertinent info required. Thanks , we are also narrowing 8 3/4 rear ends to your specs ,we have several cores,call for pricing and details,thank you.
Hi: I have motor plates ready for shipping...with and without water pumpprovisions. check my web at www.pacefabrication.net or email me with your phone number and I will contact you. Mopareddpacefab@aol.com |
| Author: | Fat49 [ Thu Nov 20, 2008 8:02 pm ] |
I thought a plate would be the ticket for swapping a slant 6 into my '49. Sent Edd specs and photos and he replied couldn't do it for my application. Not sure why. Anyone else have another source? |
| Author: | CARS [ Fri Nov 21, 2008 4:47 am ] |
That is very odd. In theory, he could cut out the needed holes for the engine in the middle of a 4x8 sheet and let you cut to fit your application. Surprising since he has basically advertised his work in every reply |
| Author: | Fat49 [ Fri Nov 21, 2008 4:47 pm ] |
Yea- I can't help but think it was a misunderstanding. I have a message out to him now. We'll see. The old flathead in my photo is coming out. The slant six is going in. |
| Author: | slantzilla [ Fri Nov 21, 2008 6:12 pm ] |
If you want to try and make your own all you need to do to start is trace out a water pump gasket on some cardboard and make yourself a template. Cardboard is a lot cheaper to experiment with than aluminum. |
| Author: | Big T [ Fri Apr 22, 2011 7:59 pm ] |
| Post subject: | Plate |
I picked one up from EDD while MATS..... So far so good.... I will try to finish the install tomorrow....Need a piece of angle iron to finish it off, so I can attach it to the frame rails. Again Thanks Edd!!!! |
| Page 2 of 2 | All times are UTC-07:00 |
