| 122 tooth SFI Flywheels https://slantsix.org/forum/viewtopic.php?t=26107 |
Page 2 of 2 |
| Author: | DionR [ Wed Dec 05, 2007 8:51 pm ] |
Quote: Why not just adapt a small block bellhousing and then you could use the 130 tooth flywheel. Opens up a lot more options including aluminum SFI flywheels and 10 1/2" clutches.
With what? AR doesn't make an adapter anymore, and the cast iron ones are heavy and as hard to find as hens teeth.Plus, I don't think the bigger bell fits under the floor well. Could be wrong but seems to me that the floor has to be "massaged" to fit the bigger bell. Where do you get an aluminum SFI 130 tooth flywheel for a slant? Flip side is it would give me the option of using a scattershield, 'course, they fit even worse. Can't see it happening. |
| Author: | JamiePasson [ Thu Dec 06, 2007 11:54 am ] |
Normally, I would just do that. The problem is that this is for a vintage racer in England. The parts used MUST be circa '60-'67. So, his hands are tied. He has to use the factory small bellhousing. Thus the problem. Jamie |
| Author: | Dart270 [ Thu Dec 06, 2007 12:27 pm ] |
OK, I know who you are working with - cool project. The Tilley fly/clutch package would work in that small BH. Cheers mate, Lou |
| Page 2 of 2 | All times are UTC-07:00 |
