| Charging problem in 64 dart https://slantsix.org/forum/viewtopic.php?t=26447 |
Page 2 of 2 |
| Author: | SlantSixDan [ Tue Jan 01, 2008 5:56 pm ] |
Quote: I did those tests as described. Running my bat to fld did indeed draw from my lights
What does this mean, "draw from my lights"?Quote: but my inquiry was if there was a way to test it with the voltmeter and get a reading from it.
Yes. The full-field test you say you did involves the use of a voltmeter. What reading did you obtain?
| Author: | SlantSixDan [ Tue Jan 01, 2008 6:10 pm ] |
Quote: you mentioned my ignition switch as being a culprit?
When the ignition switch is "on", it should feed +12v to the voltage regulator's "IGN" terminal. Turn the ignition on and put a voltmeter across the regulator's "IGN" terminal and ground. You should see battery voltage. If you do not, there's a fault in the ignition switch or the wiring between it and the regulator. Then check for continuity between the regulator's "FLD" terminal and the alternator's field terminal.
| Author: | Nickle64 [ Tue Jan 01, 2008 7:51 pm ] |
The reading was about 11. |
| Author: | SlantSixDan [ Tue Jan 01, 2008 9:23 pm ] |
If the reading was about 11 with the full-fielding test being done properly, then the alternator's defective and needs to be rebuilt. Heed the cautions in this thread about not buying "remanufactured" parts. |
| Page 2 of 2 | All times are UTC-07:00 |
