| 0-60 time... https://slantsix.org/forum/viewtopic.php?t=27094 |
Page 2 of 2 |
| Author: | Bren67Cuda904 [ Sun Feb 10, 2008 3:35 pm ] |
Quote: Thanks for the replies......and thanks for the part # Ted.
Are you looking for an early or late converter?O.K. I'm slower than a stock engine. I guess a Midwest 3000 converter is calling my name too. (Hey 'Zilla, if we're ever at a race together......I would be honored to ride in that car. Thanks again! http://www.slantsix.org/forum/viewtopic.php?t=27111 |
| Author: | BigBlockBanjo [ Sun Feb 10, 2008 5:47 pm ] |
Hey Bren, Yep, I need the large style ('72 crank & tranny). That is a loose converter......maybe it would stall a little less on my engine? Let me know if it's still available, and I'll shoot you a PM. I once had a Poly 318 (not a slant, but just as unique), with a Carter BBD on it, all factory. It would run 0-60 pretty quick...., and the '62 B-body power drum brakes worked great. Anyway, back on topic...good luck on the car, 'Zilla! Hope to race some of you folks in the near future... Thanks again! |
| Author: | Doc [ Mon Feb 11, 2008 11:23 am ] |
Quote: ...Cam timing and/or ign timing is likely your current big problems.
I have the exact same thinking... I bet that cam is way off centerline.Lou What is the total spark advance? Too much total advance makes a SL6 run "flat". You can do some checking and testing. It is pretty easy to check total advance with a timing light. Slants like a lot of initial (10 to 12 degrees) and about 30 degrees total, this is hard to get without recurving a distributor. Adjust the valves and loosen the exhaust lash as much as possible with-out ticking, this will help cylinder pressure. DD |
| Author: | CARS [ Mon Feb 11, 2008 11:53 am ] |
Last Sept. I took my '68 Dart to the 1/8 mile track to the "testNtune". I made dozens of passes for the hell of it, all of them were in the low 12's at 58 mph. Best was 12.092 @ 58.36mph. She was totally stock at the time. I didn't bring anything along to "test" but for the heck of it I checked the timing... the total was 40 degrees The best thing about racing a slow car is not only the sensation of a 9 sec. car blazing by you, but the fact that by the time you get past the scoreboards you can see your ET and MPH! |
| Author: | Doc [ Mon Feb 11, 2008 12:01 pm ] |
I bet if you would have adjusted your timing to something less the 40 total and made additional passes, the MPH would have increased. I tend to run more the 30 total on the street cars, doing that gives better off-idle "feel" and mpg. I knock the timing back if I do a lot of high speed driving or at the drag strip. (WOT) |
| Author: | BigBlockBanjo [ Mon Feb 11, 2008 6:35 pm ] |
Quote: Quote: ...Cam timing and/or ign timing is likely your current big problems.
I have the exact same thinking... I bet that cam is way off centerline.Lou What is the total spark advance? Too much total advance makes a SL6 run "flat". You can do some checking and testing. It is pretty easy to check total advance with a timing light. Slants like a lot of initial (10 to 12 degrees) and about 30 degrees total, this is hard to get without recurving a distributor. Adjust the valves and loosen the exhaust lash as much as possible with-out ticking, this will help cylinder pressure. DD The total advance (Minus Vac.)is probably pretty close to 32* or so. My governor slot is ~.385. (It's pretty short Initial is 14* now It's looking more and more like my cam is out of line. I am running looser lash......my cam called for .014/.014, and I'm running .016/.016. I am tempted to run it .020/.020 I'm kinda scared to loosen it too much.....it's a pretty steep ramp, and I would hate to bite a lifter. How do you know when to stop? (What kind of 'tick' are we talking about?....just short of a tap?) Thanks |
| Author: | Slant Cecil [ Tue Feb 12, 2008 6:55 am ] |
'68 V200, 225, untouched motor with 2.25" exh and 30* timing running on 13" Sears tires installed in 1976 0-60 - 11.7 What kind of cranking compression do you have? |
| Author: | Aggressive Ted [ Tue Feb 12, 2008 7:04 am ] |
Cecil, What rear end gears does your 68 V200 have? |
| Author: | BigBlockBanjo [ Fri Feb 15, 2008 8:47 pm ] |
Update: Moved initial timing to 10*, and time improved to 10 seconds!! MPG dropped to 18, but it has alot more pep now. The cam is next... |
| Author: | Dart270 [ Sat Feb 16, 2008 5:03 am ] |
Great! Moral of the story - buy a dialback timing light and spend some time on your dist curve... What is your total mech advance now? Lou |
| Page 2 of 2 | All times are UTC-08:00 |
