| CR Question https://slantsix.org/forum/viewtopic.php?t=27276 |
Page 2 of 2 |
| Author: | Dart270 [ Sun Feb 24, 2008 7:27 am ] |
You can make plenty of power with 9.5:1. 200-220HP should be no problem if everything is set up right. Lou |
| Author: | Joshie225 [ Sun Feb 24, 2008 8:38 am ] |
Quote: Hey Josh...would you mind sharing your engine specs ''when original'?? (Deck height, which head gasket)
The only thing that wasn't listed or can't be readily deduced from my last posting was the original .020" steel shim head gasket. The original combustion chamber was 62cc and the pistons were .177" below deck. To get from 7.7:1 to 10:1 with a .040" head gasket means .080" off the head (50cc chambers) and .100" off the block for a new deck height of -.077".
Just curious....because my stock engine had about the same compression as yours.....Just wanted to compare. |
| Author: | Evilsizer [ Sun Feb 24, 2008 11:34 am ] |
if you look in this thread http://slantsix.org/forum/viewtopic.php?p=172731#172731 the last post i made in it has a 10:1 CR 231ci,desktop dyno'd for 237HP. pulled from the 99 mopar mag. |
| Author: | BigBlockBanjo [ Sun Feb 24, 2008 12:48 pm ] |
Quote: Quote: Hey Josh...would you mind sharing your engine specs ''when original'?? (Deck height, which head gasket)
The only thing that wasn't listed or can't be readily deduced from my last posting was the original .020" steel shim head gasket. The original combustion chamber was 62cc and the pistons were .177" below deck. To get from 7.7:1 to 10:1 with a .040" head gasket means .080" off the head (50cc chambers) and .100" off the block for a new deck height of -.077".Just curious....because my stock engine had about the same compression as yours.....Just wanted to compare. |
| Author: | 68barracuda [ Mon Feb 25, 2008 6:44 am ] |
Tanks for all the feedback guys - keep it comming! Fanie |
| Page 2 of 2 | All times are UTC-08:00 |
