Need an engine identified
https://slantsix.org/forum/viewtopic.php?t=27583
Page 2 of 2
Author:  mdtrdr [ Mon Mar 10, 2008 8:25 pm ]
Another new with another engine to identify please.
I believe it is P1 225 r 269 5 or S cant tell on the last.
Thanks in advance
Author:  SlantSixDan [ Mon Mar 10, 2008 9:28 pm ]
Welcome on the board. Please recheck your figures. Where did you find them on the engine, and what is the engine in (or out of)?
Author:  mdtrdr [ Mon Mar 10, 2008 9:57 pm ]
Just double checked and it is P1 225 r 2695, located on the top front of the block, stamped below #1 plug. I don't know what its out of as it was already pulled. It has a 1bbl carb, air cleaner sticker says 225 charger. The block is a real "pretty" powder blue. It does have various other #s on the block, but nothing indicating the engine size ie: 806830-2 cast in front of the starter.
Thanks again
Author:  SlantSixDan [ Mon Mar 10, 2008 10:06 pm ]
Thanks again
That'll be 2806830 (-2) cast into the starter side of the block, which indicates a 1968 through mid-'76 "RG" block, which means your engine is either a 198 or 225, and not a 170. The "225" part of the stamped number indicates the engine was originally a 225, and probably still is, though the 198 and 225 use the same block (the rods and crank are the differences) so if this is a "remanufactured" unit, it could be a 198.
The "P1" at the beginning of your stamping number is probably "PT".
PT: Engine built at Trenton Engine Plant
225: Original engine displacement in cubic inches
R: Regular-fuel engine
2695: Date code. Decodes to December 13, 1968. That means this engine was originally built for a 1969-model car and would originally have been painted not the common Chrysler Blue, but a greenish-blue light turquoise colour.
Author:  mdtrdr [ Mon Mar 10, 2008 10:42 pm ]
Thanks again, I'm planning a light build, already have a offy 4,interested in a light cam and hei.
Page 2 of 2 All times are UTC-08:00
